HBOL Terminology
Discussion in 'UK Motorcycles' started by Robbo, Feb 1, 2004.
  1. Robbo
    Robbo Guest
    Shamelessly stolen from another NG
    Haynes: Rotate anticlockwise.
    Translation: Clamp with molegrips then beat repeatedly with hammer
    anticlockwise.
    Haynes: This is a snug fit.
    Translation: Clamp with molegrips then beat repeatedly with hammer.
    Haynes: This is a tight fit.
    Translation: Clamp with molegrips then beat repeatedly with a hammer.
    Haynes: As described in Chapter 7...
    Translation: That'll teach you not to read through before you start. Now you
    are looking at scary photos of the inside of a gearbox.
    Haynes: Pry...
    Translation: Hammer a screwdriver into...
    Haynes: Undo...
    Translation: Go buy a tin of WD40 (giant economy size).
    Haynes: Retain tiny spring...
    Translation: PINGGGG - "Where the hell did that go?"
    Haynes: Press and rotate to remove bulb...
    Translation: OK - that's the glass bit off, now fetch some good pliers to
    dig out the bayonet part (and maybe a plaster or two).
    Haynes: Lightly...
    Translation: Start off lightly and build up till the veins on your forehead
    are throbbing then clamp with molegrips then beat repeatedly with hammer.
    Haynes: Weekly checks...
    Translation: If it isn't broken don't fix it.
    Haynes: Routine maintenance...
    Translation: If it isn't broken, it's about to be. We warned you...
    Haynes: One spanner rating.
    Translation: An infant could do this... so how did you manage to **** it up?
    Haynes: Two spanner rating.
    Translation: Now you may think that you can do this because two is a low,
    teensy weensy number... but you also thought the wiring diagram was a map of
    the Tokyo underground (in fact that would have been more use to you).
    Haynes: Three spanner rating.
    Translation: Make sure you won't need your car for a couple of days.
    Haynes: Four spanner rating.
    Translation: You're not seriously considering this are you?
    Haynes: Five spanner rating.
    Translation: OK - but don't ever carry your loved ones in it again.
    Haynes: Bolt will be tight
    Translation: You havent a hope in hell!
    Haynes: If not, you can fabricate your own special tool like this...
    Translation: Hahahahahahahahahahahahahahahahahahahahahahaha.
    Haynes: Compress...
    Translation: Squeeze with all your might, jump up and down on it, throw it
    at the garage wall, then find some molegrips and a hammer...
    Haynes: Inspect...
    Translation: Squint at really hard and pretend you know what you are looking
    at, then declare in a loud knowing voice to your wife "Yep, as I thought,
    it's going to need a new one"
    Haynes: Carefully...
    Translation: You are about to suffer deep abrasions.
    Haynes: Retaining nut...
    Translation: Yes, that's it, that big spherical blob of rust.
    Haynes: Get an assistant...
    Translation: Prepare to humiliate yourself in front of someone you know.
    Haynes: Turning the engine will be easier with the spark plugs removed.
    Translation: However, starting the engine afterwards will be much harder.
    Once that sinking pit of your stomach feeling has subsided, you can start to
    feel deeply ashamed as you gingerly refit the spark plugs.
    Haynes: Refitting is the reverse sequence to removal.
    Translation: Yeah, right. But you swear in different places.
    Haynes: Prise away plastic locating pegs...
    Translation: Snap off...
    Haynes: Using a suitable drift...
    Haynes: Apply moderate heat...
    Translation: Unless you have a blast furnace, don't bother. Alternatively,
    Haynes: Index
    Translation: List of all the things in the book, bar what you need to do
    Haynes: Everyday toolkit
    Translation: RAC Card & Mobile Phone
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Feb 1, 2004
  2. Robbo
    Spete Guest
    Is there already a HBoL describing how to re-use ancient jokes??
    Spete, Feb 1, 2004
  3. Robbo
    Do I need to reiterate my feelings towards cut and paste repostings of
    ancient shite? Especially when carried out by twats?
    No, I thought not.
    Pip, Feb 2, 2004
  4. Robbo
    Spete Guest
    **** me, you're on a roll tonight Pip. No more alcohol in the house?
    Spete, Feb 2, 2004
  5. Robbo
    Your comment has been noted, thanks. Send beer. Stat.
    Pip, Feb 2, 2004
  6. Robbo
    Spete Guest
    You don't sound desperate enough...sorry
    Spete, Feb 2, 2004
  7. Robbo
    Your tally stick has now been notched. Sorry.
    Pip, Feb 2, 2004
  8. Robbo
    Robbo Guest
    1) DIGAF about what you think.
    2) DIGAF about your personal sad attempts at abuse
    3) Some people mayy not have read it
    HAND
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Feb 2, 2004
  9. Robbo
    deadmail Guest
    Actually I give a **** that I can't see who you're responding to.
    Could you set your attributes correctly please? Thanks everso.
    deadmail, Feb 2, 2004
  10. Robbo
    Par for the course, innit.
    You have some chance of getting him to alter the habit of a lifetime.
    Pip, Feb 2, 2004
  11. Robbo
    deadmail Guest
    But I asked nicely! I didn't call him names or nuffink.
  12. Robbo
    [of Robbo's posting style]
    That could be where you're going wrong, see. I bet you know insulting
    names that he's never heard of.
    Pip, Feb 2, 2004
  13. Robbo
    deadmail Guest
    I might, but then again since I don't know who else has been insulting
    him away from this place I could well be wrong.
    Tricky. Very tricky coves, insults.
  14. Robbo
    Christofire Guest
    Does he deliver it himself, or does Mrs. Statto do a delivery service?
    Christofire, Feb 2, 2004
  15. Robbo
    Christofire Guest
    Knock knock.
    Oh go on - you might not have heard it.
  16. Robbo
    Hello? Doorstep deliveries? I'll have 1,478 large gins, please.
    Pip, Feb 3, 2004
  17. Robbo
    Statto Guest
    Hello, Wincanton? Yes, have you still got those tankers you used when
    you were delivering Gordon's to a large house in London? Good, I
    wonder if you can help....
    Statto, Feb 3, 2004
