Head bearing trouble
Discussion in 'UK Motorcycles' started by Daz, Aug 18, 2004.
  1. Daz
    Daz Guest
    I've put the race bike back together with a new bottom *yoke* [1] and
    everything now appears straight. Unfortunately no amount of
    tightening the head bearings will eliminate all of the play :eek:(
    The new bearings I've fitted are stock Suzuki from Crescent but it
    used to have tapers in there. Would I have any more joy getting a set
    of tapers from BSL or whoever? I'd have thought they were exactly the
    same size so wouldn't solve anything but I'd appreciate the thoughts
    of those that have a clue, unlike me.
    The outer races fitted into the headstock quite easily but a mate
    reckons they should have been an *extremely* tight fit. Is he right?
    [1] For the benefit of Eddie :eek:)=
    Daz, Aug 18, 2004
  2. Daz
    Eddie Guest
    He might well be - if they fitted that easily, that's probably where the
    play is.
    I know you said the new ones are stock Suzuki, but are they the same
    size as the old bearings?
    Lovely.
    Eddie, Aug 18, 2004
  3. Daz
    Daz Guest
    A very worrying but accurate thought as the guy at Crescent said
    exactly the same thing :eek:(
    Assuming that is the case, any idea where I can get it checked/fixed?
    Daz, Aug 18, 2004
  4. Daz
    Digital Verniers? How does that work then?
    ogden, Aug 18, 2004
  5. Daz
    Eddie Guest
    As cool as digital Vernier calipers are, what's wrong with the good
    old-fashioned calipers where you had to know what a Vernier scale was to
    use them?
    Eddie, Aug 18, 2004
  6. Daz
    Eddie Guest
    Heh.
    As I'm sure you probably know, they're Vernier calipers, but they also
    have a digital readout for the numpties that don't know what a Vernier
    scale is.
    Eddie, Aug 18, 2004
  7. Daz
    TomTheKraut Guest
    Nuffink.
    But these young whippersnappers today...
    Tom :{)
    BOTAFOT#105 COFF#02/ OSOS#15 KwaSoH#2
    SR500(.de), SRX-4(.jp)
    Make it idiot-proof and someone invents a better idiot...
    Hiroshima pics: http://makeashorterlink.com/?C12E12B97
    TomTheKraut, Aug 18, 2004
  8. It was somewhere around Barstow, on the edge of the desert, when the
    Very good. 9/10
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Aug 18, 2004
  9. I think you've answered your own question.
    Mr. Fantastic, Aug 18, 2004
  10. Daz
    Eddie Guest
    Only 9/10? Where did I go wrong?
    Eddie, Aug 18, 2004
  11. Daz
    Eddie Guest
    Pah. Bloody kids today. Don't they teach them anything at school?
    Eddie, Aug 18, 2004
  12. Daz
    Of course, what you *really* want is a micrometer.
    ogden, Aug 18, 2004
  13. Daz
    Eddie Guest
    They're nice, but it depends what you're measuring, innit?
    AFAIK, micrometers don't go as large as Vernier calipers, and they can't
    be used for measuring internal dimensions.
    [Waits for evidence of 6' micrometer with internal measurement adaptor...]
    Eddie, Aug 18, 2004
  14. It was somewhere around Barstow, on the edge of the desert, when the
    You didn't, hth...
    http://www.saburchill.com/physics/chapters/0095.html
    GS 850 x2 / SE 6a
  15. It was somewhere around Barstow, on the edge of the desert, when the
    I've seen some bloody big ones in my time... wiv extensions... Ooerr...
    You can get internal micrometers, no problem.
    GS 850 x2 / SE 6a
  16. Daz
    Champ says...
    Chemical Metal :)
    Lozzo, Aug 18, 2004
  17. Daz
    platypus, Aug 18, 2004
  18. Grimly Curmudgeon, Aug 19, 2004
  19. Daz
    Eddie Guest
    OK, I sit corrected.
    But a standard Vernier caliper will do internal, external and depth - to
    make the same measurements with a micrometer you'd need three
    micrometers, wouldn't you?
    Eddie, Aug 19, 2004
  20. It was somewhere around Barstow, on the edge of the desert, when the
    For accuracy, yes. A Vernier caliper is fine for rough work to the
    nearest mil or so, but I wouldn't believe it any finer than that.
    The digital Verniers might be more accurate, but I've a feeling it's
    simply putting icing on a pig.
    GS 850 x2 / SE 6a
