Head Race bearings
Discussion in 'UK Motorcycles' started by Catman, May 23, 2006.
  1. Catman
    Catman Guest
    Getting a new front tyre fitted today, turns out the head race bearings are
    fucked.
    Talking about 2 hours labour to replace, and maybe £50 for the bearings
    themselves. Is it me, or does that sound like a lot for bearings?
    TIA
    www.cuore-sportivo.co.uk
  2. Catman
    Catman Guest
    I'm hoping to DIY with a mate who has many shiny things. Cheers for the
    estimate on the bearing.
  3. Catman
    SD Guest
    <points at Wing>
    Go on, then. Off you go.
    <starts stopwatch>
    | ___ Salad Dodger
    |_\_____/_| ..79553../..21469.../..31308.
    '^' RBR'06 Points: 75 Miles: 317
    SD, May 23, 2006
  4. Full dealer retail (ripoff), unless your bike uses something exotic. A
    set of bearings typically would be a tenner from BSL.
    Grimly Curmudgeon, May 24, 2006
  5. Catman
    Grimly Curmudgeon said...
    The trouble starts with trying to find out what bearings are required
    Lozzo, May 24, 2006
  6. Catman
    SD Guest
    The bearings for the Wing were cheaper from M&P than from my local
    friendly bearing supplier. And they were the right ones.
    | ___ Salad Dodger
    SD, May 24, 2006
  7. Catman
    SD Guest
    That doesn't just apply to the 1200.
    | ___ Salad Dodger
    SD, May 24, 2006
  8. Catman
    I reckon it'd take me at least two hours to do on the Guzzi - which is
    unfaired and not particularly complicated.
    sweller, May 24, 2006
  9. Catman
    Catman Guest
    Both of you make sense :(
    Catman, May 24, 2006
  10. Catman
    Catman Guest
    Ta
  11. That is just so much like Honda. That's why I don't like the marque.
    eric the brave, May 24, 2006
  12. Just what I was thinking.
    Pattern taper rollers are about £35, yes, but I wouldn't be surprised if
    the genuine article was £50. Actually, I remember that genuine Honda
    cup-and-cone ball bearing head races for the Benly were about £45, which
    was a shock.
    The Older Gentleman, May 24, 2006
  13. Catman
    Catman Guest
    Looks like the consensus is to let them get on with it, then.
  14. Demand chain - BSL (eg) wouldn't have the same need to get them in
    regularly.
  15. That's the problem. You have to take it apart to find out - then it's
    immobilised anyway and you might find the only source is the ripoff
    stockist. Not a problem once you've done it the first time, it's much
    easier to repeat and you know where to go; if you do a reasonable
    mileage you might need to do it again in a couple of years.
  16. *Ding*
  17. Catman
    Catman Guest
    Dunno about reasonable mileage. This is only 12500 miles old.
    I say only, but I have no idea how long it's supposed to last anyway.
  18. Catman
    ChrisDC Guest
    Market forces being what they are, I'll bet the original bearings are
    the cheapest and lowest quality that Mr. Honda et al can get away
    with, i.e. that meet their minimum durability and performance spec.
    If you know what you're doing it should be possible to get better
    quality replacements elsewhere, except in those cases where the
    bearing is a unique design.
    Mutter mutter Kawasaki wheel bearings...
    ChrisDC, May 24, 2006
  19. Catman
    SD Guest
    He might have. I've got a Sprint battery in mine.
    | ___ Salad Dodger
    SD, May 24, 2006
  20. Catman
    SD Guest
    .... and, if it's the Honda bit, it comes with a dust/grease seal to
    replace the one you smashed to bits getting the lower bearing off the
    steering stem.
    | ___ Salad Dodger
    SD, May 24, 2006
