Heat dispersal issues with Bicycle brakes
Discussion in 'UK Motorcycles' started by Bob123, Jun 26, 2004.
  1. Bob123
    Bob123 Guest
    I ride down Hill a lot (full story below) and occasionally get a smell
    of burning rubber which until now I always assumed was probably the
    pads, however my rear tyre just blew at the point where the tyre touches
    the wheel rim and could easily have taken me with it so how do I either
    fit disk brakes to a bicycle that wasn't designed to take them, or can
    you think of another solution?
    As some may know I'm currently living in Hong Kong, you may also be
    aware of the fact that we have a hill hear abouts, from which on a nice
    clear balmy night like tonight you get a fabulous view of central and
    Kowloon. I've just returned from an evening photographic section on the
    peak, [1] and as I've done 3 times before I took my fold up bicycle [3]
    as riding down is a hoot, the vertical decent is over 500 meters and
    there are 2 routes you can take, either Old Peak Road [4] and Magazine
    Gap and I decided to take the later.
    Having taken a load of photos I climb on the bike and head off, slowly
    gathering speed, I'm quickly overtaken buy a pizza delivery boy on a
    50cc moped but 2 minutes later I sail past him glancing on the way past
    at his speedo which reads 50 Kmph. It's a lot of fun as you can imagine
    but can't last forever and about 15 minutes later I arrive at the place
    just before the bottom of the hill where I have to haul on the brakes
    [5] and turn into a car park to get home, this all goes according to
    plan and I get off the bike to push it up the short hill back to my
    block [6] but as I'm pushing the bike the rear tire blows taking about 3
    seconds to deflate fully, "**** me" thinks I "nice of it to do it now".
    Any advice on how to continue riding down hill like a nutter but avoid
    this potentially lethal side effect of using the brakes too much would
    be great fully received.
    [1] nothing serious, I'm an armature but I get some good [2] photos
    [2] in my opinion
    [3] this time in the back of a cab but I have used the bus and the Peak
    Tram in the past
    [4] the word road is misleading as it's preposterously steep, it's no
    longer open to vehicular traffic as we now have the very long but not so
    steep Magazine Gap, I went down it on the push bike a couple of months
    ago and when I arrived at the bottom I noticed this smell of burning
    rubber and realised that I had tested the endurance of the brakes on the
    bike to the limit. I have vaguely asked about fitting disk brakes to the
    rear wheal as I use these to control my speed and only use the fount to
    stop and been told that is is not possible.
    [5] not that I didn't have the brakes partially on most of the way anyway
    [6] It's not possible to approach it from above
    Bob
    Currently borrowing a black and red Yamaha XJ750 with fuel injection
    Present: Honda XL125RF (FS)
    Past: Honda CG125
    bob at homeurl tomato dot co dot uk
    remove the red fruit if you’d like to email me.
  2. Bob123
    Is there a link to them? Could generate some interest.
    sweller, Jun 26, 2004
  3. Bob123
    Colin Irvine Guest
    If not I'm sure it could be rectified.
    Colin Irvine, Jun 26, 2004
  4. It might take several people. Working on a rotor basis.
    The Older Gentleman, Jun 26, 2004
  5. The Older Gentleman wrote
    If current theories hold true.
    steve auvache, Jun 26, 2004
  6. Bob123
    Sean Guest
    Nah, he's winding us up.
    Sean, Jun 26, 2004
  7. Bob123
    Ben Guest
    Sounds like the brake is badly adjusted and the block is rubbing the
    tyre on braking.
    But anyway, you can get brackets that will allow fitting of an
    International Standard caliper to a non-disc frame but they aren't too
    good. They flex a lot. You could probably get a good framebuilder to
    braze a mount on though, if it's a steel or ti frame.
    As far as forks are concerned it'd be cheaper an easier to replace the
    fork with one that already has a disc mount.
    Disc brakes do rock, I wouldn't be without them now.
    Ben, Jun 26, 2004
  8. I think he's gone ohm now.
  9. Bob123
    Catman Guest
    Well, don't start coiling him names
    www.cuore-sportivo.co.uk
    Catman, Jun 26, 2004
  10. Bob123
    On the 18:15 ex-Victoria with all the other commutators.
  11. Watt's that?
  12. Do you leave the breaks on for a long time? It's better to repeatedly apply
    them hard for a short while then release them for a bit to give them chance
    to cool down rather than keeping them on at a low pressure for a long time.
    David Johnston, Jun 26, 2004
  13. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember
    (The Older Gentleman) saying
    something like:
    He's given us the brush off, slipring away like that.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jun 27, 2004
  14. Bob123
    Bob123 Guest
    Just checked, there is a full 1.5 ~ 2 millimetres of clearance so 'snot
    that.
    It's an aluminium frame as sadly titanium would be nice but wasn't on
    offer, one of these
    http://www.yeahbikes.com/yra062.htm
    I don't mind if the brakes flex a bit, particularly on the back as this
    is the one I drag to control my speed so the brackets sound ideal, any
    idea who makes them (URL?) as when I asked in a shop for precisely that
    all I got was blank looks and then when I had explained my self I was
    told it was impossible?
    Don't think I'll find forks to fit my frame with disk fittings.
    Certainly the difference going from drum to disk on the Motorbike was
    huge but the current V-brakes have got plenty of stopping power, the
    power on the front brake is very lumpy as the wheel rim is not smooth
    but that's not the end of the world, if I can find forks with disk
    fittings I'll change over but it's not as important as the rear.
    Oh and thanks for the non "Oh look here's a wanker who can't spell"
    response.
    Bob
    Past: Honda CG125
    Bob123, Jun 27, 2004
  15. Bob123
    Bob123 Guest
    They don't.
    Cos the power on the front brake is very lumpy as the wheel rim is not
    smooth and as the hills f'in' steep, I've got to use some braking.
    Ah but you guys are so much more intelligent.
    Bob
    Past: Honda CG125
  16. Bob123
    Bob123 Guest
    But the hill is steep and if I want to go down it at a controlled speed
    I have to convert the same amount of kinetic energy into heat [1] as I
    have a fixed amount of gravitational potential energy and doing it in
    short bursts would mean the temperatures would be even greater.
    [1] I know that air resistance increase with the square of velocity but
    I'm going to ignore it
    Bob
    Past: Honda CG125
  17. Bob123
    Ben Guest
    Looking at the bike I don't think you'll be able to. There's simply
    not enough room for them at the back and you won't be able to fit them
    to the forks.
    Also I dunno how much the folder cost, but ones I've seen haven't been
    that expensive and mtb disc brakes run to around 60 quid per brake for
    cable operated ones and 100 plus per brake for hydraulics. Probably
    be more cost effective to buy a new bike with them fitted.
    And beat in mind cheap disc brakes are worse than v-brakes.
    Ben, Jun 27, 2004
  18. Bob123
    Ben Guest
    You really need to sort the front brake. It's much more powerful than
    the rear, meaning you can use it less and still slow down the same
    amount.
    Dragging the rear all the way down a hill is bad news, as you've
    found.
    Ben, Jun 27, 2004
  19. Bob123
    foyrnb Guest
    Nope, you are all missing the point. (Or I am just about to)
    Your tyre blew because the wheel rim heated up because of brake
    application over a long-ish period of time.
    A fault of naff rims and/or a badly fitted tyre. The hot wheel rim
    expands and the tyre beading loses grip.
    Either get yourself a proper wheel with smooth beading and better heat
    dispersion properties or do as Dave(? sorry fucked attributions) said
    above and apply the brakes in short bursts that allow the wheel rim time
    to cool a bit between applications.
    foyrnb, Jun 27, 2004
  20. Bob123
    Bob123 Guest
    It's got to take the same amount of energy out so I'd have thought it
    would get just as hot, if I used both brakes that would distribute the
    energy and reduce the heat. I tried to sort the front brake but the lump
    is where the wheel rim is joined and the shop didn't think there was
    anything they could do, got any suggestions?
    Bob
    Past: Honda CG125
