Heated clothing for the Pikeys?
Discussion in 'UK Motorcycles' started by dwb, Jan 27, 2006.
  1. dwb
    dwb Guest
    dwb, Jan 27, 2006
  2. dwb
    Steve Parry Guest
    Autocom do a 12v to 9v adaptor for the basic intercom system so I guess
    one of those could be bodged to fit.
    Alternatively, connecting to the HT leads may work ;)
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    http://www.nwbikers.co.uk
    Steve Parry, Jan 27, 2006
  3. dwb
    Rusty Hinge Guest
    The message <>
    You might need some sort of trembler and transformer, or inline
    resistor, depending on the working voltage.
    If you try it, don't forget to have a concentric in-line plug and socket
    in the supply because you *WILL* forget it is connected, one day...
    Rusty Hinge, Jan 27, 2006
  4. dwb
    dwb Guest
    My GPS is 9V too, so that aspect is easy to do I think (not for me
    obviously, I will blow myself up).
    I'm just wondering if the coat itself is actually any good as it's
    about ?100 cheaper than any other one I've seen.
    dwb, Jan 27, 2006
  5. I think they missed out "every 15 minutes" after it says "Requires 6x
    AA batteries"
    Chris D
    Chris N Deuchar, Jan 27, 2006
  6. dwb
    'Hog Guest
    I'm waiting for a set of 'leccy gloves from GLF, shall report back on
    the effectiveness of said item. I don't see the point of heated grips on
    an unfaired Bandit and have terrible circulation to the paws.
    'Hog, Jan 27, 2006
  7. dwb
    dwb Guest
    Those will be fine as they're decent expensive kit.
    In this case I'm interested because it's cheap :)
    dwb, Jan 27, 2006
  8. dwb
    <snip>
    Chris. Fucking sort this abortion out, eh?
    You always add "Chris D" (which surely ought to be part of the .sig)
    *above* the *upper* separator: the upper separator doesn't work (in
    Agent, at least) because there's another one below it.
    FFS slip your name beneath a separator and bin the extra one, then it
    wil all work nicely.
    Pip, Jan 28, 2006
  9. The reason for the double separator is that I have a 'standard' set of
    bookmarks which I refer to with a variety of programs. This one (ie
    Gravity) also adds its own sep (none of the others do). Until your
    post I hadn't realised there was a problem with the double sep. Is
    this the real version of Agent we are talking about - or the Free
    Pikey Agent BTW? Any one else affected by any other prog?
    I sometimes add other comments post 'Chris D' so I will hang onto it
    for now...
    Chris D
    (Spare sig sep for sale on ebay: item number 3-zillion-and-one: Used)
    Chris N Deuchar, Jan 30, 2006
