Heights
Discussion in 'UK Motorcycles' started by Paul Corfield, Dec 29, 2003.
  1. I am scared of heights and found it very unnerving to be presented with
    a precipitous and windy viaduct on a TOG French Run - I made it across
    but only just :-(
    I was wondering if any ukrmer who suffers from vertigo has managed to
    deal with their fear and cope with the roads, bridges and tunnels that
    dangle or thread their way through mountains and valleys. I read the
    tales of great trips to France, Switzerland and Italy and feel I am
    destined to never ride those roads unless there is some clever solution
    or helpful tips. (Helpful) Suggestions welcome.
  2. Paul Corfield
    Ben Blaney Guest
    I'm terrible with heights. Riding and driving over bridges doesn't
    bother me, though I don't like walking over them (I have to shut my eyes
    and hold the rail to cross the bridge to the Tate Modern).
    Really, I don't know. IIRC it's an issue even if you don't look down -
    which indicates that it's the thought of the height, rather than the
    view of it. So... hypnotherapy?
    Ben Blaney, Dec 29, 2003
  3. Paul Corfield
    Andy Hewitt Guest
    Facing your fear is the only way really. I have a great fear of height
    myself, and cannot even manage a ladder for more than a few rungs.
    However, I have still managed to go mountaineering, skiing and even fly
    in a microlight. I have also helmed a 72ft narrow boat across the
    highest aquaduct in the UK.
    Some of the things I did on mountains make my heart jump now, but I did
    them, and I'm still here. I even held a Scouts Mountain Leadership
    certificate. It can be done, you just have to puch yourself to overcome
    it.
    Andy Hewitt, Dec 29, 2003
  4. Paul Corfield
    Colin Irvine Guest
    When I started skiing about ten years ago I had to keep my eyes shut
    on chair lifts. I can now handle even really high ones, and can ski
    steep slopes. I assume that the change is simply down to familiarity.
    I still can't go out on balconies, but I can do (in fact revel in)
    mountain passes - as long as I keep away from the edges.
    Trying to find logic within the above I suggest
    1) Finding the nearest bit of road that scares you and riding it over
    and over again - I'm pretty sure it will eventually stop scaring you.
    2) When you do start to feel scared, concentrate on the road and how
    much good solid tarmac is all around you. It probably won't work on
    bridges (Pat has trouble with them) because you know there's space
    underneath, but it might just work on terra firma.
    Are scary roads less so if you're on foot? If so, why?
    Colin Irvine, Dec 29, 2003
  5. Paul Corfield
    Ben Blaney Guest
    And on a similar note Paul, how do you feel about being on a train going
    across a bridge?
  6. Paul Corfield
    MikeR Guest
    I'm just plain weird with heights. Cliffs, mountains, great yawning
    chasms : no problem whatsoever. Air travel - both light aircraft and
    big jets : everything just jim dandy.
    Put me on the edge of a building, bridge, or some other man-made
    structure though, and I cack my pants.
    I freaked out a few weeks ago just looking at the Clifton suspension
    bridge, never mind actually going over it.
    Very odd.
    MikeR, Dec 29, 2003
  7. Paul Corfield
    mups Guest
    Heights I'm ok with but I do get claustrophobic which I tried curing by
    taking up caving and scuba diving and even ended up doing a few cave dives
    in Hodge Close [1]. I still break out in a cold sweat if say the tube stops
    in a tunnel but I find it much easier to control. I suppose the same works
    with vertigo, start off slow and with what you feel is controllable and
    work your way up so to speak.
    [1] Yea, yea I know Hodge is not a *proper* cave but it's close enough for
    me
    mups, Dec 29, 2003
  8. Paul Corfield wrote
    If you want to get to the other side of the bridge then you either go
    across it or go around. Frankly I can't be arsed to go around so I just
    get on with it and don't look down.
    Or to put it another way, if you keep your eyes on the road like you
    should be doing then the scenery is not an issue is it?
    steve auvache, Dec 29, 2003
  9. Paul Corfield
    Linger Guest
    Linger CR250
    TFSTR#? |BOTAFOF#43 |SKOGA#(can't find the number) |BBB#4 |BHaLC#7
    Linger, Dec 29, 2003
  10. Paul Corfield
    Linger Guest
    I'm the same with ladders!
  11. Paul Corfield
    Andy Hewitt Guest
    Yes, I can relate to that, a hard rocky mountainside is certainly
    different to a man made object.
  12. Paul Corfield
    Linger Guest
    ARSE!
    Sorry
  13. Paul Corfield
    Buzby Guest
    Parachuting. You *won't* look back.
    Buzby
    Buzby, Dec 30, 2003
  14. Paul Corfield
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    It's quite common. The chaps at the Dartford crossing apparently have to
    deal with it quite frequently (they drive the person across I believe).
    That sounds eminently sensible.
    Nigel Eaton, Dec 30, 2003
  15. Paul Corfield
    You need to work up to freefall?
    Akcherly looking out the door over the jump zone always gave me the wobbles.
    Healthy that IMHO.
    Hog, Dec 30, 2003
  16. Paul Corfield
    Colin Irvine Guest
    As I've said above, Pat is. I've asked her about it and she can't
    explain why. She's no chicken (well you've seen for yourself how
    relaxed she is on the back of a Thunderace at eek mph). Yet whenever
    we cross the Forth road bridge I have to drive, and at well over the
    speed limit, as she holds her breath the whole way over!
    Colin Irvine, Dec 30, 2003
  17. Paul Corfield
    Ginge Guest
    That's me as well.
    When in that kind of situation thoughts like "will this balcony crumble
    away" and "I wonder if the handrail is loose" enter my mind.
    I chose to ignore my fear by focussing on something else instead, which
    isn't always easy.
    Ginge, Dec 30, 2003
  18. MikeR wrote:
    Whilst in Amsterdam with an ex who is as heights phobic as all of you
    here have mentioned, we did the trip round Anne Franks house.
    There's one piece of corridor where the floor is clear plastic/glass.
    There's a staircase below it, and there is no alternative but to go over
    it. It's just big enough that you probably need 2 steps across to clear it.
    Now in order to help convince said ex it was safe, I stood on it.
    Jumped. Lots. Of course this should have demonstrated how strong it was
    (I am not exactly lightweight). But in her head, I was making it worse.
    Took bloody ages to get over it, with me in the end having to virtually
    drag her over because of the mounting queues behind being rather
    unsympathetic. I was not thanked.... :(
    Doesnotcompute, Dec 30, 2003
  19. Paul Corfield
    Ginge Guest
    I thought that bridge was cool, I don't like heights but being in the
    middle of a bridge, and a fair distance from the edge I didn't see a way
    I'd fall off it.
    I really liked the huge bridge I rode over on the way back from Normandy
    this year. http://www.technologystudent.com/struct1/norman1.htm
    Ginge, Dec 30, 2003
  20. Paul Corfield
    Brownz Guest
    Focus ..... mmmmm ..... pies.......
    Brownz, Dec 30, 2003
