Helmet strength.
Discussion in 'UK Motorcycles' started by toad_oftoadhall, Aug 14, 2006.
  1. It's also possible to tell by hitting it with a shovel a second time in
    the same spot, and trust me you can hit the same spot over and over
    hard with the edge of a shovel and you cannot get a mark on the GRP.
    Indeed assuming the GRP in the helmet behaves the same way as GRP in a
    boat (I bet it does) when if finally goes give way it will flex for a
    while first keeping the polystyrene in situ.
    I think you are seriously under estimating the strength and resiliance
    of the outer shell of a helmet if you think a drop from normal drop
    height will harm it.
    toad_oftoadhall, Aug 15, 2006
  2. toad_oftoadhall
    Kim Bolton Guest
    Lurking.....;-)
    Kim Bolton, Aug 15, 2006
  3. toad_oftoadhall
    Kim Bolton Guest
    Did you like the way I weaved that in to the discussion? It's amazing
    where Materials Science lead one...ROFL
    Ah! Isn't it just....;-)
  4. toad_oftoadhall
    Kim Bolton Guest
    But the critical damage won't necessarily show....
    Well, I was jujst trying to point out some of the considerations;
    you're quite free to disagree with them or ignore them, and what
    decisions you make regarding these things are entirely up to you. It
    isn't my head that's at risk ;-)
  5. Right, this helmet had a bike fall on it.
    By this stage you're arguing there would be critical damage the helmet
    is now weak. (Indeed I thought that was the case which is why the
    helmet was scrapped)
    Then it was thrown at the ground as hard as poss.
    *Then* it was hit hard with a shovel. About 100 times over the time I
    was playing. I could barely mark it.
    On that basis I would argue that no critical damage had been done at
    all in that first stage of abuse. Indeed I wold argue that to weaken
    the structure would take a significant blow that would be very visible.
    Indeed given my experience of GRP in boats I'm strongly doubting that
    'invisible' damage due to blows is even possible. The gel coat is so
    weak relative to the GRP that there would always be signs.
    Or trotting out the conventional propaganda?
    Is there any evidence anywhere of a helmet that has been rendered
    dangerously weak following a light blow, invisible on the helmet?
  6. toad_oftoadhall
    The helmet manufacturers say so.
    In a circumstance where the padding material will not be compressed,
    like it rolling off a bike seat, and there being little or no visible
    external damage, my £20 says it's good as new.
    I have broken the chin piece of two Arai. A Giga and an RX7RR. The first
    in an MX off and the second in a track spill. It requires a highside
    type free flight manoeuvre, I think after these two trial runs I have it
    down pat <fx\ roll camera> I've never successfully split the main shell
    of anything but an old (80's) Polycarb AGV.
    Remember the toughness of the outer shell is also to do with abrasion
    resistance, as Statto proved recently.
    Hog, Aug 15, 2006
  7. toad_oftoadhall
    I always thought Kimberley Rew was a woman, til I went to a Soft Boys
    gig.
    ogden, Aug 15, 2006
  8. That's where my money's going. Now I can fully understand how the
    padding is a 'one use' deal (indeed every time you pull it over your
    head you're reducing its effectiveness).
    .....in contrast the shell appears to be pretty indestructable.
    An interesting side issue is: Could you hit someone wearing a road
    legal helmet with a shovel hard enough to kill them? I reckon you might
    be able to. To prove it, all we need is a shovel, a helmet and John
    Prescott.
  9. toad_oftoadhall
    Not if you understand material science. The material may age but gentle
    compression below the yield point should have no effect.
    Kill them? depends on the weight of the shovel I imagine. You can
    certainly hit someone a glancing blow with a helmet (1) hard enough to
    knock them sensless *and* shatter the wire reinforced glass door behind
    ;o)
    (1) the helmet does not however remain serviceable, surprising and
    upsetting.
    Hog, Aug 15, 2006
  10. WIth f**k all knowlege of physiology I reckon any and all of th eblows
    I delivered would have damaged the helmet wearer - my first thought is
    "wouldn't that just snap the neck?"
  11. toad_oftoadhall
    Eiron Guest
    I reckon it was the edge of my helmet that broke my collarbone.
    Perhaps the lower edge of helmets should be more padded or rounded.
    Eiron, Aug 15, 2006
  12. toad_oftoadhall
    Kim Bolton Guest
    I wasn't arguing anything. I was - or so I thought - showing what
    mechanism lay behind the potential weakening and possible failure of
    fibre-composite helmets; and that such weakening or failure was
    difficult if not impossible to assess without expensive detection
    equipment and expert analysis.
    The military, especially when considering aerospace structures, are
    extremely concerned about non-visible damage to structural composite
    components, and have spent much time and effort searching for ways
    merely to assess such damage.
    I thought I was trotting out some Materials Science.
    What you make of it is up to you.
    A good question. I don't know, but I'm sure there are others on here
    who might.
  13. I think it you repeatedly hit it with a shovel and it always bounces
    off you can say the weakening is *very* limited.
    I'm not denying non-visible damage exists in some contexts. I'm saying
    helmets are still very strong even after minor impacts.
    That's why I asked.
  14. toad_oftoadhall
    Hog says...
    I have, in the shop, so did one of my customers. The helmet in question
    was an AGV Ti-Tech; yes, the same model as still used by one Valentino
    Rossi. The then Arai rep showed me the fault, just pick the helmet up
    and grab both sides of the chinstrap, pull them apart to compress the
    cheekpads prior to pulling the helmet on and the shell would crack from
    visor aperture to base of the chinbar on both sides. I demonstrated the
    fault to a customer who insisted on trying one, it did exactly the same
    thing when he tried to put one on.
    At the time the Ti-Tech was the latest hot-poop helmet to come out of
    any factory and Gericke UK had the first ones off the production line.
    I'd only just put 24 of the things out on display, they all went back in
    their boxes ready to be returned and I refused to sell them or any other
    AGV helmet again.
    Lozzo, Aug 15, 2006
  15. toad_oftoadhall
    M J Carley Guest
    One of my colleagues, who works on composites for aerospace
    applications, tells me that the manufacturers are most worried about
    technicians dropping things on the wing during maintenance. I'm with
    Kim on this one.
    M J Carley, Aug 15, 2006
  16. toad_oftoadhall
    I never bought another AGV either!!
    Hog, Aug 15, 2006
  17. It can be worse. One of my friends at Uni was called Kym, the more-
    usual feminine spelling; he got lots of letters from the womens' clubs when
    he turned up for Fresher Week.
    Dr Ivan D. Reid, Aug 15, 2006
  18. toad_oftoadhall
    Kiran Guest
    Err, I've obviously missed this - what happened? Google link will do - can;t
    seem to find anything meself.
    Kiran, Aug 15, 2006
  19. toad_oftoadhall
    Kiran says...
    It's only Ogden, wgaf?
    Lozzo, Aug 15, 2006
  20. toad_oftoadhall
    Not something I'll be describing in detail on ukrm. Catch me on MSN if
    you're curious.
    ogden, Aug 15, 2006
