helmets
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Jan 29, 2009.
  1. Zebee Johnstone, Jan 29, 2009
  2. Zebee Johnstone
    Big Bird Guest
    head will remain intact but neck will snap like a twig.
    Big Bird, Jan 29, 2009
  3. In aus.motorcycles on Thu, 29 Jan 2009 20:10:07 +1100
    from the article:
    In the case of fatal accidents, there was one more important
    discovery in the Hurt Report: There were essentially no deaths to
    helmeted riders from head injuries alone.
    Some people in the study, those involved in truly awful,
    bone-crushing, aorta-popping crashes, did sustain potentially fatal
    head injuries even though they were wearing helmets. The problem was
    that they also had, on average, three other injuries that would have
    killed them if the head injury hadn't.
    In other words, a crash violent enough to overwhelm any decent helmet
    will usually destroy the rest of the body as well. Newman put this
    into perspective. "In most cases, bottoming [compressing a helmet's
    EPS completely] is not going to occur except in really violent
    accidents. And in these kind of cases, one might legitimately wonder
    whether there is anything you could do."
    How many people were saved because their helmet was designed to a
    "higher" or "higher energy" standard than the DOT standard? As far as
    the Hurt researchers could ascertain, none.
    In other words, the latest relevant study, which used state-of-the-art
    methods and covered accidents in countries where there are plenty of
    10-second, 160-mph superbikes running around, concluded that current
    standards - even the relatively soft[1] ECE standards - are allowing
    riders' heads to be routinely subjected to forces that can severely
    injure or kill them.
    [1] "soft" meaning they allow fewer Gs than Snell because they focus
    on that rather than on penetration and impact resistance - ZJ
    Moral of the story? Rubber side down is better than all the
    alternatives.
    Zebee
  4. Zebee Johnstone
    Yeebok Guest
    Still reading but it's quite thought provoking.
    Yeebok, Jan 29, 2009
  5. Zebee Johnstone
    Yeebok Guest
    In Oz though, providing you are being legal you don't have that many
    standards to choose from, do you ? I did like the 'ranty' response from
    Snell which really had little humour in it apart from the garlic
    reference. I can see how they felt snubbed but the testing and
    methodology to me, at least, made a good deal of sense.
  6. In aus.motorcycles on Thu, 29 Jan 2009 21:11:29 +1100
    You get Snell on some helmets, else you get AS1698.
    I'm trying to get info on the G requiremenst for AS1698.
    Zebee
  7. In aus.motorcycles on 29 Jan 2009 10:24:36 GMT
    And straight from the tester (Derek Wainohu who does the testing for
    1698)
    AS/NZS1698:2006 consists of the following;
    Internal projections; no greater than 5mm but any greater than 2mm
    require testing
    External projections; no greater than 5mm
    At least six helmets of the same size shall be submitted for testing
    ISO Headforms are required
    Testing sequence:
    Peripheral vision not less than 105 degrees
    Helmet stability (dynamic) not rotate more then 30 degrees
    Impact energy attenuation not to exceed 300g
    Resistance to penetration no contact of the striker with the
    headform
    Strength of retention (static) not to exceed 25mm
    so 1698 allows the same Gs as Snell (300) and more than DOT (250) or
    ECE (slightly higher than DOT but the article doesn't give a number
    that I found).
    So everything you buy with a 1698 sticker will transmit *less* than
    300 to your bonce, but no way to know how much less.
    I'm asking Derek for more info, so stay tuned.
    Zebee
    Zebee Johnstone, Jan 30, 2009
  8. Zebee Johnstone
    Diogenes Guest
    That's 300g in what size area?
    e.g. 300g in 0.001sq mm will pierce the skull.
    Am I being silly?
    Onya bike
    Gerry
    Diogenes, Jan 30, 2009
  9. In aus.motorcycles on 30 Jan 2009 00:36:57 GMT
    1.8m Flat anvil
    1.38m Hemispherical anvil
    2 impacts on each test site
    Helmets perform better than the 300g
    So similar idea to Snell, but 6 foot and 4 foot drops rather than 10
    foot and 7 foot.
    Zebee
  10. In aus.motorcycles on Fri, 30 Jan 2009 11:40:39 +1100
    yes :)
    It's either a flat anvil that's bigger than the helmet curvature, or a
    round one. Don't know the size, but I bet it's tennis ball or bigger.
    Zebee
  11. Zebee Johnstone
    Diogenes Guest
    Oh.... Alright...
    Onya bike
    Gerry
  12. Zebee Johnstone
    Diogenes Guest
    Sounds fair enough to me. But now this raises the question (for me,
    anyway) What does 'Impact energy attenuation not to exceed 300g'
    actually mean?"
    Onya bike
    Gerry
    Diogenes, Feb 2, 2009
  13. Zebee Johnstone
    GB Guest
    I did read that bit of the standard, and it did use a lower case 'g'.
    That said, I agree with your interpretation. (Actually, IIRC, I don't
    need to rely on your interpretation. Somewhere near where it said
    '300g', it defined 'g' as being a unit of accelleration of 9.8m/s/s)
    So yeah, what Big said, AND what Gerry said.
    GB
    GB, Feb 2, 2009
  14. I read it as 300G too, but the argument is still valid. 300G over a
    small point is more likely to pierce the helmet than a larger impact
    area. But as that great bloke Zebee posted, the impact tests due you
    larger impact devices.
    Kevin Gleeson, Feb 2, 2009
  15. Zebee Johnstone
    madbiker666 Guest
    Head cant survive with out a body to support it though, well not for
    long anyway. i think any impact strong enough to destroy a helmet, the
    rest of the body wont survive anyway.
    madbiker666, Feb 4, 2009
  16. In aus.motorcycles on Mon, 02 Feb 2009 16:12:18 +1100
    read the article that I pointed to at the beginning of this thread.
    It is explained there.
    Zebee
    Zebee Johnstone, Feb 10, 2009
