Help: 2 gallons to the mile.
Discussion in 'UK Motorcycles' started by Molly, Jan 21, 2007.
  1. Molly
    Molly Guest
    I went to start my GSX600F and the fuel gauge was showing empty. It was full
    the last time I took it out and that was only to Tescos, about a mile round
    trip. I put a can of petrol in it and it started to leak out on to the
    patio. I removed the fairing and found it dripping from the seam where the
    bottom of the tank meets its side, near the fuel tap. There are no holes or
    rust spots it just looks like the seam has come away. Any ideas where I can
    get it fixed (cheaply) please.
    Molly, Jan 21, 2007
  2. Molly
    Nige Guest
    Whats the tank made out of Molly? You have many options, but a mega
    cheap fix for any petrol leak is blu-tac. It solidifies when in contact
    with petrol & is a great 'get you home' fix.
    'nothing up top but a bucket & a mop & an illustrated book about birds'
    Nige
    Subaru WRX (54)
    Land Rover 101 GS/Ambi (Morph)
    BMW 650 GS Dakar
    2000 Suzuki GSX1300R Y Hayabusa
    KTM 520 SX
    Nige, Jan 21, 2007
  3. Molly
    Robbo Guest
    As Nige says....Temporary fix though.
    Drain it, wash out thoroughly with strong soapy water of the like, leave
    open to dry and take to nearest engineering shop and get mig welded. Might
    be more tricky if alloy, so maybe look for a local ally welder.
    Unless you can spread the crack slightly and squeeze araldite between the
    seam and clamp up it's gonna possibly need a paint retouch after welding
    Robbo, Jan 21, 2007
  4. Molly
    Molly Guest
    It's made out of steel.
    This is a picture of it. I actually managed to catch the drip. You can see
    the seam has dropped down.
    http://www.sportsbike.org/leak.jpg
    Molly, Jan 21, 2007
  5. Molly
    Nige Guest
    A bloke i know used a big fook off tube & did it from the inside but
    you dom have to be pretty precise.
    Nige
    Subaru WRX (54)
    BMW 650 GS Dakar
    KTM 520 SX
    Nige, Jan 21, 2007
  6. Molly
    Nige Guest
    hhhmmmm, tricky one, how much is a new tank? eBay could be your friend,
    i got a new tank for the old ZZR for £30, less than it would cost for
    some bloke to make big holes in it with his welder etc!
    Nige
    Subaru WRX (54)
    BMW 650 GS Dakar
    KTM 520 SX
    Nige, Jan 21, 2007
  7. <checks pic>
    That's fucked, and the other side will soon follow it. Find a decent
    used tank.
    The Older Gentleman, Jan 21, 2007
  8. Molly
    TMack Guest
    Ebay item 220053776569 - then spray it the colour you want.
    TMack, Jan 21, 2007
  9. Molly
    Beav Guest
    So what's wrong with brazing it? No holes and a permanent repair.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 21, 2007
  10. Molly
    Nige Guest
    It's steel matey. New tank for me.
    Nige
    Subaru WRX (54)
    BMW 650 GS Dakar
    KTM 520 SX
    Nige, Jan 21, 2007
  11. Molly
    Molly Guest
    This is what I thought of doing?
    Molly, Jan 21, 2007
  12. Molly has brought this to us :
    It would need to be brazed, but with it being a petrol tank you may
    have some difficulty persuading anyone attempt it due to the risk of it
    exploding. I had the same problem years ago and the suggestion was that
    it had to be steam cleaned, then filled with exhaust fumes to prevent
    it exploding whilst brazing it - the guy was not though willing to have
    a go at it, too great a risk said he.
    Harry Bloomfield, Jan 21, 2007
  13. Molly
    Robbo Guest
    No problem brazing steel.
    Although seeing the pics EBay is your friend
    Robbo, Jan 21, 2007
  14. Molly
    Moon Badger Guest
    As TOG and others have said, it is fooked. The other side will go next, then
    the bit that is just under the nose of the seat.
    Get thee to a breakers or ebay or partsearch, and no, you're not having my
    spare.
    Moon Badger, Jan 21, 2007
  15. Molly
    BGN Guest
    It's pink?
    BGN, Jan 21, 2007
  16. Molly
    mb Guest
    Brazing you could prolly do yourself. Remember: flame plus petrol = BANG.
    mb, Jan 21, 2007
  17. Molly
    Molly Guest
    I've just bought it, cheers.
    Molly, Jan 21, 2007
  18. Molly
    Molly Guest
    Molly, Jan 21, 2007
  19. Molly
    Molly Guest
    message
    Good enough for me. I've just bought one. Cheers.
    Molly, Jan 21, 2007
  20. Molly
    raden Guest
    Would JB Weld not be a good thing to fix this with ?
    raden, Jan 21, 2007
