Help! Ignition/electrical
Discussion in 'UK Motorcycles' started by 8_bit, Feb 9, 2004.
  1. 8_bit
    8_bit Guest
    Recently returned to biking, but my 1986 Suzuki DR600 won't start :( Its a
    600 single cylinder with two sparkplugs coming off one ignition coil. I
    don't have a spark. I have changed the plugs and plug caps, charged
    battery - used a booster battery, etc. When it was nearly dark, I did see
    a weak spark when I held a bare ht lead just off of the engine.
    I have got a multimeter.. Can anyone tell me how the hell I can get this
    thing going again - what and how to test? Pleaaasse...
    Paul (yes, another)
    Thetford Forest Archaeology
    <URL:http://www.aoqv41.dsl.pipex.com/>
    8_bit, Feb 9, 2004
  2. 8_bit
    Steve Parry Guest
    In
    from what I can see at
    http://www.motofiches.com/sites/TYRBUW/fiches.asp?cs=&mk=SUZUKI&cc=600&ml=DR600&id=SN41A
    its appears to be electronic ignition not points
    Steve Parry
    http://www.gwynfryn.co.uk
    K100RS SE
    F650
    Steve Parry, Feb 9, 2004
  3. 8_bit
    Petel Guest
    Check the coil first..
    Primary resistance (between HT leads) should be up in the 10KOHM range.
    Secondary resistance (power from loom and wire from CDI unit) should be
    either 2 or 3 OHM.
    Check the manual for exact figures, anything varying more than 10% +or-
    means a new coil.
    Check your getting power to the coil.
    Double check the battery and connections.
    Check the clutch cut-out and side-stand switches (if fitted).
    If this all checks out suspect the CDI unit.
    HTH.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Feb 9, 2004
  4. 8_bit
    8_bit Guest
    8_bit, Feb 9, 2004
