[Help] rear hyd brake won't release
Discussion in 'Motorbike Technical Discussion' started by Sean, Jun 26, 2006.
  1. Sean
    Sean Guest
    I knew there was a problem when my Ultra Classic didn't seem to coast
    very well; something seemed to be grabbing it. The rear brake pedal
    action seemed wrong, too, as if the master cyl was already engaged.
    So like an idiot I blistered my thumb testing whether the rear brake
    disc was warm... shit that was hot. And the color's a bit blue.
    I've been riding this bike to work but it looks like I'll have to
    take the van until I can figure out how to get the brake to
    free up. Can anyone give me a quick fix so I can at least ride
    the bike to the repair shop?
    TIA, Sean_Q_
    '99 FLHTCUI
    Sean, Jun 26, 2006
  2. Sean
    Sean Guest
    Thanks guys, will try.
    Sean_Q_
    Sean, Jun 26, 2006
  3. Sean
    anybody43 Guest
    Rear brake not releasing
    I think that this could also be caused by the master cylinder's
    piston not returning to its correct rest position. In turn this could
    be
    the result of the lever not being adjusted properly or I guess
    corrosion or other gunge in the cylinder. There should be a
    small amount of "free play" in the lever before the hydraulic
    piston starts to move.
    anybody43, Jun 26, 2006
  4. Sean
    sharkey Guest
    Yep, what he said. (Or crap in the MC, or sticky piston seals, or ...
    but it's worth checking the MC piston returns fully before you do
    anything expensive!)
    -----sharks
    sharkey, Jun 27, 2006
