HEY, I'LL EVEN MAKE IT SIMPLER. JUST O-N-E LITTLE QUESTION SO AS NOTTO OVERLOAD THE TINY MIND OF TO
Discussion in 'Motorcycle Technical Discussion' started by Bill Miller., Aug 24, 2008.
  1. Bill Miller.
    Bill Miller. Guest
    On the TW200 I thinking of buying, I understand it comes with a stock
    50 rear sprocket.
    What will be the performance results of changing the rear sprocket to
    a 47 or a 42?
    By performance results I mean mpg, shift points, higher speed and
    quieter engine operation, and any other aspects of ON-ROAD RIDING.
    Okay, here's the simple format for the simple-minded.
    Bill, if you change the rear sprocket from a 50 to a 47, the following
    performance features will be altered.
    1.
    2.
    3.
    Bill, if you change the rear sprocket from a 50 to a 42, the following
    1.
    2.
    3.
  2. Bill Miller.
    Bill Miller. Guest
    No, Geyser the Troll, you only proved you shouldn't quit your day job
    if you hope to make it as a wordsmith.
    And BTW, say hello to your anal companion TOG TURD for me next time
    you two get together in his "secret playroom."
    Bill Miller., Aug 25, 2008
  3. Easily answered if you can provide the shift points and speed for
    a given rpm of the 50 tooth sprocket.
    As for the mpg - very likely, no change will result. The reason
    why is that at any given speed it takes a certain amount of power
    to overcome the wind resistance to move you down the road.
    There is a given amount of energy in each gallon of gas. Changing
    the gearing isn't going to add energy.
    The only time the gearing will help mpg is if you spend most of your
    time at a specific rpm, and that rpm is out of the most efficient
    point at which the engine makes mechanical energy, and your gearing
    moves that rpm back into the most efficient point at which the
    engine makes mechanical energy.
    Think about it - if your going 50mph and you shift from 4th
    to 5th gear, and your RPM drops by 1K, all that happens is
    that the amount of fuel-air mixture that is sucked into each
    cylinder on the intake stroke increases - because the amount
    of power strokes per mile has decreased, so in order to keep
    going at the same speed, each power stroke has to make more power.
    Ted
    Ted Mittelstaedt, Aug 25, 2008
  4. Bill Miller.
    S'mee Guest
    It's a dirt bike you shit. All you will do is blow up the motor...then
    again you have intimated you like blowing things up.
    dipshit trolls like you are an embarassment to the other trolls...you
    don't even. Oh never mind you are obviously too stupid to learn
    anything.
    S'mee, Aug 25, 2008
  5. Bill Miller.
    Bill Miller. Guest
    S'mee, calling me a troll, when Hankster, in another thread, has
    already IDed Keithy S'mee as the TRUE TROLL of the newsgroup.
    Bill
