Hhmmm....
Discussion in 'UK Motorcycles' started by Nige, Jun 20, 2007.
  1. Nige
    Nige Guest
    Washed the MT-03 today as it was utterly filthy. After washing it,
    even though it was in first, i kicked up the stand & pulled in the
    clutch, hit the start button & the fucking thing lurched forward as if
    in gear, not the clutch was fully in & it was in gear.
    I have never known this happen before on any bike?
    Stuck clutch? I gave it a rock or two in gear, tried in vain to find
    any kind of neutral. Eventually, I got neutral & it then started as
    normal.
    Any ideas? It's off for it's first service on Monday. Now & again on a
    run it kind of doesn't find the gear right & either bounces out of
    gear, could be me not pegging it, but i doubt it after riding a blade
    for many miles.
    'That is one bad hat Harry'
    Nige
    Land Rover Discovery II (2001)
    Honda CBR900RR Fireblade (1997)
    Yamaha MT-03 (2006)
    Nige, Jun 20, 2007
  2. Nige
    I have. If the bike's been standing overnight then sometims the plates
    don't separate properly. My TL was like that.
    Pip Luscher, Jun 20, 2007
  3. Nige
    Nige Guest
    Hope so then, it's bloody ace to be fair.
    Cheers
    Nige
    Yamaha MT-03 (2006)
    Nige, Jun 20, 2007
  4. Yes. Nothing to worry about.
    The Older Gentleman, Jun 20, 2007
  5. Nige
    Paul - xxx Guest
    Every Trials bike I've ever had dids that .. plates stick when left
    overnight or longer, but are fine when nice and warm.
    Paul - xxx, Jun 21, 2007
  6. Nige
    Nige Guest
    Odd, never had it on any of mine.
    Nige, Jun 21, 2007
  7. Nige
    Switters Guest
    Happen(s/ed) on both mine.
    Switters, Jun 21, 2007
  8. Nige
    Sounds fairly normal for a wet clutch bike. Happened on my CBr6, VFR750 &
    TDM850. Normally manifests itself by a noisy clonk as you engage 1st gear.
    Generally, I parked the bike in neutral, started the bike normally and then
    held the clutch in for 15-20 secs before engaging 1st gear. This usually
    eliminated the problem.
    wessie, Jun 22, 2007
  9. Nige
    Eddie Guest
    WTF? Who could be arsed? Bang the fucker in and get on with it.
    Eddie, Jun 22, 2007
  10. Nige
    IME some bikes are worse than others. As for ancient designs with
    plates with cork inserts...
    Pip Luscher, Jun 22, 2007
  11. Nige
    I take it you've never ridden a TDM850?
  12. Nige
    I had one of the very earlier ones and heartily concur with Pip's
    solution - a strong left ankle is all that's required.
    _______
    Ace, Jun 22, 2007
  13. Nige
    Eddie Guest
    You take it right. Why should that matter?
    Eddie, Jun 22, 2007
  14. Nige
    The 'box on that bike was especially bad. I little bit of heat in the oil
    made it quite a bit better.
    It only mattered to me because I don't like to hear the noise. That's the
    best rationalisation I can offer. Pretty piss poor, really, considering my
    usual form.
  15. Nige
    No it wasn't. It worked perfectly well, all the time, as long as you
    didn't try and pussy-foot around with it.
    _______
    Ace, Jun 22, 2007
  16. Nige
    Eddie Guest
    *cough*
    Eddie, Jun 22, 2007
  17. Nige
    Eddie Guest
    I suppose it's more mechanically sympathetic, but I expect that most
    people have better things to do than sit there for 20 seconds with the
    clutch held in.
    Eddie, Jun 22, 2007
  18. And someday you end up with a noisy main bearing at the clutch end.
    DAMHIK, IJK, OK.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Jun 22, 2007
Similar Threads
Loading...
