HID conversions?
Discussion in 'UK Motorcycles' started by Hog, Oct 20, 2010.
  1. Hog
    nicknoxx Guest
    Ho yuss, those mbt boys are making lights with over 2000 lumens
    nicknoxx, Oct 22, 2010
    #81
  2. Hog
    Colin Irvine Guest
    That makes sense. However, I think it makes more sense for both
    parties to have the wick turned down so that you're driving partly on
    night vision.
    It used to be, and may still be (paging davethedave), that in
    countries like Turkey drivers coming towards each other would take it
    in turns to switch off their headlights completely for several seconds
    so that the other driver could see more. It worked partly because the
    overall brightness of headlights was far less than it is now, but you
    could see and you weren't blinded. There's far too much traffic for it
    to work here, but it is an example of the brighter not always being
    the better.
    Colin Irvine, Oct 22, 2010
    #82
  3. Hog
    boots Guest
    Certainly seems to be the case in Egypt that lights are turned off
    outside of towns, not really sure that's good or not.
    boots, Oct 22, 2010
    #83
  4. Hog
    Switters Guest
    They certainly do that in Egypt. Good idea me thinks.
    Switters, Oct 22, 2010
    #84
  5. Hog
    Catman Guest
    Precisely how is that sloppy thinking?
    ar?bi?tra?ry [See pronunciation table in "How to use dictionary" pages]
    decided or arranged without any reason or plan, often unfairly:
    Seems to be quite the reverse of sloppy (depending on your choice of
    definition of 'reason' of course)
    www.cuore-sportivo.co.uk
    Catman, Oct 22, 2010
    #85
  6. Hog
    Colin Irvine Guest
    Perhaps "sloppy" is the wrong word - "lazy" might be better. Let me
    give an example.
    Suppose I need to decide, for whatever reason, whether or not someone
    (a man) is "clean shaven". An hour after he has shaved clearly he
    will be. A month after he's shaved he clearly won't.
    You could easily claim that it's impossible for me to say whether or
    not someone's clean shaven simply because I would have to fix some
    arbitrary point during that month where the man changes from being
    clean shaven to not. But, if I were an officer in the armed forces,
    for example, I might need to decide just that.
    You could take it a stage further, and start trying to tie me down to
    the precise minute when he lost his "clean shaven" status.
    Ok, "sloppy" is the wrong word. But do you see what I'm getting at?
    Claiming that you can't divide a continuum simply because where you
    draw the line to divide it must of necessity be arbitrary is lazy,
    intellectually.
    #86
  7. Hog
    davethedave Guest
    There are no time limits. You can argue until the Amazons rock up.
    davethedave, Oct 22, 2010
    #87
  8. Hog
    Catman Guest
    Then it's an opinion. I don't think any officer would argue otherwise.
    Yes. As most people do you have an opinion and you are trying to work
    out some way in which it seems to be fact so you can argue that you're
    right, and everyone who disagrees is wrong. This is normal human behaviour.
    I made no such claim. I simply aimed to point out that your *opinion*
    that HID's [1] are 'unecessarily bright' is just that, an opinion. Other
    people have different ones, just a valid.
    [1]And there's a generalisation.
    #88
  9. Hog
    Ben Guest
    I've always thought the idea of only allowing sidelights in built-up,
    street lit, areas was a good one.
    There is enough light to see by, no one gets dazzled, sides are enough
    for others to see you, and cyclists and peds will be more visible
    because they don't get lost in the light arms race.
    Ben, Oct 23, 2010
    #89
  10. Hog
    boots Guest
    I've bought new bikes where on turning on the lights for the first
    time the beam is aimed skyward - so much for PDI.
    boots, Oct 25, 2010
    #90
