high visibility in leeds
Discussion in 'UK Motorcycles' started by mike, Dec 10, 2003.
  1. mike
    mike Guest
    Just to let you know of a new shop in Leeds called Active Workwear at
    56 Bradford Road, Pudsey, opposite Chris Richards Motorcycles!!!!
    that can supply all manner of High Visibility and or waterproof outer
    clothing clothing at competetive rates email or tel 0113 256 6655
    mike, Dec 10, 2003
  2. mike
    mb Guest
    Got anything in black?
    mb, Dec 10, 2003
  3. Got any HiVis Kilts?
    Doesnotcompute, Dec 10, 2003
  4. mike
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, mike
    Look mummy, a spammer.
    Oh, and look! A spammer's phone number. What *fun*...
    Nigel Eaton, Dec 10, 2003
  5. mike
    Linger Guest
    " Hello, can I speak to Mr Brightstripe please, first name Ivor."
    Linger, Dec 10, 2003
  6. **** off.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 11, 2003
  7. mike
    Rexx Guest
    That would be the new ultraviolet reflective black leathers, that only
    highlight you when being approached by boy racers with blue LEDs on their
    cars. :)
    (Yes, I do know, I have one of those blue LED torches, it makes
    flourescent things show up rather well, meaning it produces a fair old
    whack of UV.)
    Rexx, Dec 11, 2003
  8. mike
    christofire Guest
    I thought LEDs only produced one wavelength, therefore if you can see
    them they aren't doing UV?
    christofire, Dec 11, 2003
  9. mike
    Rexx Guest
    Dunno, but it's a blue LED and it charges up glow in the dark things
    quicker than a normal lightbulb, and makes flourescent things flouresce
    rather brightly. A plain blue wavelength wouldn't actually make it
    flouresce, would it - as flourescence is due to reflecting UV?
    Rexx, Dec 11, 2003
  10. mike
    Alan.T.Gower Guest
    I bet a car crashes into it. SMIDY.
    Alan
    http://www.ads-training.co.uk
    "Kneesliders Sponsored by Cane"
    GSX-R1000 , Triumph Thunderbird, ZXR750L2 Racer(gone), GS500,
    GHPOTHUF#27
    TGF, UKRMFBC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://sportsbike.org (our own endurance team) http://Team-ukrm.com
    "Nemo repente fuit turpissimus"
    Alan.T.Gower, Dec 11, 2003
  11. mike
    christofire Guest
    If all it did was reflect UV then it wouldn't do anything - you wouldn't
    be able to see it. It absorbs then re-emits the light at a longer
    wavelength, shifting it towards red colours. It's all to do with
    electron shells, IIRC my physics correctly.
    Therefore, it could be UV as you say, but it could also be just blue or
    violet light. This doesn't prove that LEDs do or don't produce one
    wavelength. I suspect they do, as different colours are made using
    different gasses. When used in light production gasses typically only
    produce one wavelength.
    If any of the resident physicists want to jump on my sweeping
    statements, feel free.
  12. mike
    I don't think that's the case. AIUI each electron/shell jump would
    emit a photon at a given wavelength determined by the energy expended
    to make that jump, but most gases consist of many shells with
    different energy levels.
    Consider most domestic flourescent lights. They generate a reasonable
    approximation of white light, don't they? Consisting of a very wide
    range of different wavelengths.
    IANAP. Should I have let that stop me?
    Ace, Dec 11, 2003
  13. Gasses in LEDs? Nope.
    LEDs work by combining electrons with holes at the interface
    between two different types of semiconductor. The electron + hole
    then gives up some energy, which is specific to the types
    of semiconductor. Multiwavelength semiconductors use multiple
    "blocks"[1] of semiconductors.
    [1] I'm not sure of the exact configuration.
    William Grainger, Dec 11, 2003
  14. mike
    christofire Guest
    Yes, but I thought they were made up of other LEDs. I'm happy to be
    proven wrong, and an explanation of how it's done would be welcome.
  15. William Grainger, Dec 11, 2003
  16. mike
    christofire Guest
    Aha. I assumed semiconductors, doping, gasses, one wavelength. Little
    knowledge, and all that I think.
    Ta muchly.
  17. mike
    christofire Guest
    Ah yes, but that's made up from as little as 5 different gasses mixed,
    giving off 5 wavelengths. I thought each LED made 1 wavelength, and
    you'd stick multiple ones in one lens to create white or compsite
    colours.
    However, will's given the word, so I obviously need to do some reasearch
    in the physics section next time I'm at the library.
    Hell no. This is UKRM.
  18. Indeed; not fantastically "white" though.
  19. Harsh, but fair.
    Mr. Fantastic, Dec 11, 2003
  20. mike
    flashgorman Guest
    SMIWD
    Sorry mate i was dazzled.
    flashgorman, Dec 11, 2003
