Hmm..
Discussion in 'UK Motorcycles' started by Phil Launchbury, Aug 29, 2007.
  1. Airbag light has come on in the Voyager (105K on the clock, minor scuff
    down the left hand side, S reg..).
    Question - worth fixing or junk?
    Phil.
  2. Phil Launchbury
    Nige it out on ebay and buy WUN's Voyager to replace it.
    platypus, Aug 29, 2007
  3. Phil Launchbury
    Greybeard Guest
    A lot of time they only need resetting.
    Might be worth disconnecting the battery for 24 hours, and while the battery
    is disconnected, check the wiring connectors to the airbag. These may have
    corroded a tad or come loose. Don't forget to make sure the earth is good.
    Worth a try.
    Greybeard
    FLHTCUI UK-07 Mk II (Sold)
    Trumpet Trophy 1200-03
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Aug 29, 2007
  4. Phil Launchbury
    antonye Guest
    Have a Google, as it might be an easy fix. In the old
    3-series (E36) that we recently sold, the airbag light
    coming on is a well-known problem with the wiring under
    the seat for the seatbelt pretensioners [1] which starts
    to corrode after 5~6 years and then upsets the system.
    You could sometimes get away with just resetting the error
    in the car's memory to turn the light off, otherwise
    it's replacing the dodgy cable at £15 - even cheaper
    if you follow the interweb instructions and remove
    the connectors then solder the wires together.
    A trip to a friendly dealer who can scan the car's
    system would probably be your best bet.
    [1] is that the right word? Sounds like a dodgy 80s band.
    antonye, Aug 29, 2007
  5. Phil Launchbury
    Adrian Guest
    Phil Launchbury () gurgled happily, sounding much
    like they were saying :
    Option 3 - live with it.
    Airbag light's not an MOT fail, so no issue. OTOH, it's almost certainly
    iffy connections to the seatbelt pretensioners. Half an hour's furtling
    should see it right.
    Adrian, Aug 29, 2007
  6. If its an OBD or OBDII car you can buy a connector and plug it into
    the usb port of a laptop. My mate
    bought one for his Seat Ibiza from ebay for £15 and downloaded the
    diagnostic software to read faults/reset faults etc.
    Miles Reading, Aug 29, 2007
  7. I had a quick google and checked for something called the clock spring
    (a part in the steering column that tends to fail on Voyagers and is a
    £50 fix) but since my horn still works it can't be that..
    Hmm.. I didn't think ours had pretensioners.. it may do though.
    It's booked in for Monday for investigation - if it costs more than a
    couple of hundred I think I'll go the 'trade in to a non-Chrysler
    garage for something else' route. We don't have room to keep it and
    sell it privately while driving something else and I don't particularly
    want to drive it without airbags because that would give the insurance
    people a perfect reason for refusing an injury claim..
    Phil.
  8. No - but it is a reason for an insurance personal injury claim to be
    refused (given how wonderful and understanding insurance companies
    are!).
    I've booked it in for the garage to have an investigate. If it's going
    to cost lots to fix it's going to get traded in.
    Phil.
  9. Phil Launchbury
    antonye Guest
    I doubt it will be the airbag - the major cost of
    the system - as these rarely fail. The system itself is
    very sensitive, understandable given the parts involved,
    and will thus err on the side of caution. You can trigger
    an error just by doing something silly like knocking the
    connector while vacuuming under the seat.
  10. Phil Launchbury
    Is it really, or is this just a guess? It wouldn't surprise me if it
    is true, mind.
    CT, Aug 29, 2007
  11. It's an educated guess..
    Phil.
  12. I can't remember when I last did that. And I have a good memory.
    Although it does get a free[1] valet when it has a service..
    Phil.
    [1] Free as in 'paid for by the extortionate hourly rate'
  13. Phil Launchbury
    Adrian Guest
    DFC.
  14. Well yes. But you'd be amazed how many people manage not to see
    something the size of a Chrysler Grand Voyager bearing down on them at
    high speed..
    Phil.
  15. Phil Launchbury
    AW Guest
    Take the bulb out of the light, fuse it and replace.
    Sorted.
    AW, Aug 29, 2007
  16. It can. The clock spring carries the wiring for the horn and the airbag
    (4 wires in total). Only 1 of the 2 airbag ones needs to break.
    John
    John Greystrong, Aug 29, 2007
  17. It's become largely academic - as I was driving it to work this morning
    the auto box started making a horrible whining noise (full-on Des mode)
    and being very slow at changing ratio - and when it does change ratio
    it makes a huge clunk as it drops into gear. Also when I put my foot
    down the whining noise gets a lot louder but the car doesn't accelerate
    like it normally used to.
    At a guess I'd say the torque converter is on its way out..
    transmission fluid levels are normal (my first thought) and I can't see
    any signs of obvious damage to anything in the engine bay.
    Phil.
    Phil Launchbury, Aug 31, 2007
  18. Phil Launchbury
    Des Guest
    Remind me again of how I 'deserved' that...
    D.
    Des, Aug 31, 2007
  19. Phil Launchbury
    My first thought would be "Does it lurk on UKRM?"
    platypus, Aug 31, 2007
  20. <Petard mode>
    It's Usenet - what I say doesn't matter remember?
    </PM>
    Phil
