Honda CB400T question
Discussion in 'UK Motorcycles' started by eatmorepies, Mar 16, 2011.
  1. eatmorepies
    eatmorepies Guest
    The throttle on the 400T won't return by itself. I've taken the carbs off
    and undone the cables at the carb end - then lubed the cables - they seem ok
    when not attached to the carbs. When I reassemble the non-return problem
    remains. Routing seems o.k. The spring on the carbs seems to be quite
    strong - it takes a fair amount of effort to open the throttle and only
    gentle pressure to close it.
    Is a new pair of cables likely to cure this one?
    John
  2. eatmorepies
    Does the cable return ok if you unhook it from the throttle housing? If
    so, there's your answer.
    Krusty, Mar 16, 2011
  3. eatmorepies
    Mark Olson Guest
    Agreed.
    Routing is quite important, don't assume that it isn't the problem because
    there aren't obvious kinks in the cables.
    Mark Olson, Mar 16, 2011
