Honda CBX750 clutch/front sprocket/neutral indicator light switch question
Discussion in 'UK Motorcycles' started by Peter Ackers, May 13, 2011.
  1. Peter Ackers
    Peter Ackers Guest
    Hi all.
    A quickie question if I may?
    Having issues with the neutral indicator light on my Honda CBX750F.
    Getting into neutral is OK but the little light doesn't always come on :-(
    I'm guessing the neutral indicator light switch is a bit
    gunked up as its a pig to get the light to light -
    and without that lit the bike thinks its in gear so you have to pull the
    clutch to start etc... I'm guessing if I can remove the switch and clean
    it up it will be OK. But, it sits behind the front sprocket cover.
    Here's a pic of the offending area:
    http://imageshack.us/photo/my-images/19/clutcharea.jpg/
    I think the neutral switch is around when the number 4 is?
    As you can see from the photo, it looks like clutch fluid has seeped out and
    brought the black paint off.
    Can I assume if I undid bolts 1, 2 and 3 all the clutch fluid would pour
    out?
    I do have a workshop manual but the photos are terrible and the description
    very vague to say the least! I don't have a Haynes manual.
    Basically, I want to
    o) clean the neutral switch so it hopefully works better
    o) Stop the fluid weeping (not sure if it is still is weeping to be honest -
    but I
    want to sort it so it looks better)
    This may all be basic stuff once you know the answer!
    Cheers and many thanks
    Peter
  2. Peter Ackers
    TOG@Toil Guest
    Yup
    It's usually near the gear shaft, yes. Duinno where it is exactly on
    this bike.
    No. You'd just release the slave cylinder from its housing.
    I can't see any evidence of a leak, and it's behind the cover, so who
    cares if it looks a bit bare?
    TOG@Toil, May 13, 2011
  3. Peter Ackers
    Peter Ackers Guest
    "TOG@Toil" wrote in message
    Ah, awesome. many thanks. Hopefully will do that then soon!!
    Only that the paint is coming /come off on the front sprocket cover hence I
    thought it was the result of a small leak.
    I can't see a leak now to be fair so maybe its just from some mishap in the
    past?
    Its only vanity :)
    Cheers and many thanks, much appreciated.
    Peter
  4. Peter Ackers
    TOG@Toil Guest
    Well, to be exact, you'll remove the slave cylinder housing from the
    crankcase. Don't squeeze the clutch lever while it's unbolted or the
    piston may pop out and then you definitely will have fluid everywhere.
  5. Peter Ackers
    Peter Ackers Guest
    Ah, cool. Good tip, many thanks :)
    I know its a minor thing when the light doesnt come on but its a pain in the
    ass!!
    cheers
    Peter
  6. Peter Ackers
    Hmm. You say that, and I lived with it on the Bandit for over a year,
    but it meant that I coudn't start it to warm it while on the side stand
    - had to be centre stand or sit astride with the sidestand up. I'd
    already disconnected the clutch switch as that was a royal PITA when the
    choke cable let go and I had to apply and hold the choke manually -
    providing two left hands is beyond me.
    The MoT tester made mention of it too, so I believe it to be a 'minor'.
    Visual confirmation of netrality is useful, though, and I will be fixing
    it when I rebuild the box.
    The Ural has a different take on this aspect, as one might expect:
    random neutral light. In gear, out of gear, it lights when it feels
    like it - although, strangely, rarely when the box actually is in
    neutral.
    Pip, May 13, 2011
  7. Peter Ackers
    Peter Ackers Guest
    Quickie update.
    Stripped the offending switch out - cleaned, lubricated etc and reassembled.
    All went pretty well so many thanks for the advice and help.
    I also renewed the clutch fluid (a mate helped coz I didn't have a bleeding
    tube!! we then played with a cool outboard stuffed in a big barrel - ace
    fun!)
    Today was the first chance I've had to test it and it does seem better
    though its early days. The clutch feels better for new fluid too.
    I've no idea if a neutral indicator light switch is a standard item from
    model to model but we'll see how it goes and if it needs renewing, sort it
    then.
    So, many thanks for helping out, much appreciated.
    ps - still need a rear carrier/rack if anyone has one gathering dust in
    their garage/shed. Beer tokens await.....
    Cheers
    Peter
    Peter Ackers, May 17, 2011
  8. I've seen identical units used on different bikes, so I'd be very
    surprised if yours is unique to the CBX750.
    The Older Gentleman, May 18, 2011
  9. Peter Ackers
    Peter Ackers Guest
    "The Older Gentleman" wrote in message
    That's what I figured but wasn't 100% sure.
    Fingers crossed it will be OK but you just never know.......
    Cheers
    Peter
    Peter Ackers, May 18, 2011
