Honda CX500
Discussion in 'Australian Motorcycles' started by ivan kavinski, Feb 25, 2005.
  1. Returning to motorcycling after seeing off the kids etc - from a friend have
    been offered an immaculate 1982 CX500 (95,000km) at a reasonable price
    ($1800). The main use will be pottering around and recreational riding in a
    rural (blacktop) area. I am looking for advice/comments on this machine and
    its ilk regarding their strengths and weaknesses. Thanks.
  2. In aus.motorcycles on Fri, 25 Feb 2005 21:50:25 GMT
    The plastic maggot is a heavy, slow, reliable old thing with slightly
    odd handling.
    There are lots of bits for them in England, fewer here but they are
    about.
    It won't set the world on fire, but it will provide pottering about well
    enough.
    Hmm.. it was the maggot that had the alternator in the middle of the
    engine wasn't it? Best be very sure that the electrics are in top class
    condition and the alternator is charging correctly.
    Zebee
    Zebee Johnstone, Feb 25, 2005
  3. ivan kavinski
    Oh Well Guest
    You Make it sound far worse than it is... If you have the replacement on
    hand
    it takes less than 1 hr to replace and ride off again..
    ( with out taking every thing off the eng including the radiator )
    Try this link " Ivan " as it will answer most of your questions
    http://groups.msn.com/AustralianHondaCX500CX650Register
    Oh Well, Feb 26, 2005
  4. ivan kavinski
    IK Guest
    The only way that's a reasonable price is if he's actually offering you
    two CX500's.
    It might be immaculate, but it's 23 years old. There are_much_newer
    bikes which can be had for that sort of money, especially if you don't
    limit yourself to shafties.
    IK, Feb 26, 2005
  5. ivan kavinski
    sharkey Guest
    It'd have to be more than just immaculate for $1800, IMHO. Perhaps
    gold plated, or previously ridden by Elvis or something.
    Not that CXen aren't good bikes, and 100,000 isn't that bad for a CX,
    but the later ones ('E') have far better brakes, suspension and chassis.
    Actually, now I think about it, I'm not sure what year the 'E' models
    started ... what brakes does this one have, dual-pot or single-pot?
    -----sharks
    sharkey, Feb 26, 2005
  6. Don't these bikes have the barrels as part of the crankcase so the engine
    has to be stripped down the get a rebore? It might be up for one at this
    stage of it's life. Not something I would like to contemplate. Separate
    barrels for me.
    Stephen
    Stephen Robinson, Feb 26, 2005
  7. ivan kavinski
    vifer Guest
    Had one for nearly a year and enjoyed it, in a strange kind of way. Mine
    was the custom model 500C, raked handlebars, stepped down seat..
    Handling is pretty ordinary, braking with small diameter Front disk and rear
    drum was very average but enough to pull the bike up from <60km/h.
    There's more than enough of vibration for freeway speeds but can be dampened
    somewhat from reaching your skull with some foam grips, sheepskin etc..
    Check the usual suspects, drivetrain, swingarm play, suspension leaks, wheel
    bearings and coolant leaks. All not too expensive to fix but worth a
    bargaining chip.
    Cheap to maintain with lat heads ( valves) , can run on dino oil, clutch is
    cabled ( so keep spares ) and consider changing the brake lines to braid if
    they are still original.
    The main reason I bought mine was a cheap commuter but quickly discoverd how
    outdated it was in today's metro/commuter traffic. Decent scooters ( >125cc)
    would blast the CX from the lights nearly always, so became very hesitant in
    grabbing pole position at the lights. If you live away from the
    husttle'n'busstle or most of your riding is freeway stuff, then you'd be ok.
    I you intend to 2up now and again, take your pillion with you and try it
    out. Then you'd really gauge how underpowered it is.
    They called it the "poor mans guzzi" but i'd be more confident with a guzzi
    ( even a V50 ) than a CX500 for the riding i do.
    If you're not hooked on the CX's good looks, why not see what else 2K would
    get you. Yammie XJs, XS's? Kawa Z's and GPZ's? far more enjoyable and
    versatile bikes in my opinion.
    vifer
    vifer, Feb 26, 2005
  8. ivan kavinski
    Aido Guest
    What Yr & what were the Turbo CX500s like? I've seen one around a few Yr
    ago, I know they're an import, But just curious.
    Aido.
    Bikeless.
    Aido, Feb 26, 2005
  9. Yeah, but the CX500 is a CLASSIC!, IK.
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Feb 26, 2005
  10. ivan kavinski
    David Guest
    They were sold here by Honda Australia, from memory in the mid 80's.
    Interesting technical excercie, but with mega-lag unfortunately.
    David
    David, Feb 26, 2005
  11. ivan kavinski
    John Guest
    Sorry Peter.... we all know the CLASSIC is the Kawa gpz900R
    beer mate?
    Johno
    John, Feb 26, 2005
  12. ivan kavinski
    JustAL Guest
    How's that? Because some stumpy actor gave everyone the impression he was
    chasing F14's down the runway on one?
    Pah!
    JustAL
    JustAL, Feb 26, 2005
  13. The GPZ900R is THE classic.
    The CX500 is still A classic. :)
    Cheers
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
  14. ivan kavinski
    Gary Woodman Guest
    ....newer, betterer bikes (probably even the GPX250)...
    We shafterers don't see it as a limitation, more of an escape.
    Gary
    Gary Woodman, Feb 28, 2005
  15. ivan kavinski
    Yes, watch the alternator stator windings. They weren't well
    secured,
    I'll second that, it only takes about an hour once you've done it 3 or
    4 times... ;-)
    (A trolley jack is handy, though!)
    BT Humble, Feb 28, 2005
  16. ivan kavinski
    They're all right, but I wouldn't pay $1800 for one unless it had new
    tyres and brake pads, 12 months of rego, and a set of panniers full of
    bottles of good vodka. ;-)
  17. ivan kavinski
    Conehead Guest
    Pah! There is no such thing as good vodka.
    Conehead, Feb 28, 2005
  18. ivan kavinski
    sharkey Guest
    I find you can hide the taste with good scotch whisky.
    Drink the whisky first, and hide the taste of the vodka
    by giving it to other people.
    -----sharks
    sharkey, Feb 28, 2005
  19. Plenty of food for thought in that lot and a few chuckles as well - thanks
    all for the replies - ivan
    ivan kavinski, Mar 2, 2005
  20. ivan kavinski
    sharkey Guest
    No worries. Whoever mentioned the reboring problems was right,
    by the way, it's a pain in the ring.
    -----sharks
    sharkey, Mar 2, 2005
