Honda Nighthawk question
Discussion in 'Motorcycle Technical Discussion' started by Ivan Vegvary, Apr 20, 2007.
  1. Ivan Vegvary
    Ivan Vegvary Guest
    1985 Honda 450 Nighthawk.
    Rebuilt carburetors, adjusted valves etc. etc.
    Cleaned fuel petcock (strainer) and noticed that I cannot blow air through
    it. Read in the manual that vacuum from the engine opens the port and
    allows gas to flow. Does this mean that I will have difficulty with initial
    starting since my craburator bowls are empty? Should I manually feed gas
    into the carburator prior to starting?
    Advice appreciated.
    Ivan Vegvary
  2. Ivan Vegvary
    Bruce Farley Guest
    You should not have a problem. There will be enough vacuum created when
    the starter cranks the engine over.
    Bruce
    Bruce Farley, Apr 20, 2007
  3. Ivan Vegvary
    Ken Abrams Guest
    YMMV. While the above is probably true, it WILL take longer than "normal"
    to start. May take 15~20 seconds (of cranking time) to get enough fuel in
    the bowls. Battery needs to be fully charged and shouldn't crank for more
    than ~5 sec. continuously, IMHO.
    Is there not a PRI (prime) position on the petcock lever?
    If there is, that position by-passed the vacuum cut-off and lets fuel flow.
    Set it there for a couple of minutes and check for leaks B4 cranking.
    Ken Abrams, Apr 20, 2007
  4. Ivan Vegvary
    Mark Olson Guest
    I agree with Ken. On some bikes, cranking will supply enough vacuum to
    turn on the petcock, on others it won't, even continuously spinning
    the starter beyond the point of abuse. My '81 CB900C was one of the
    latter. Most of my Kawasakis had a PRIme position on the petcock that
    would fill the carb bowls without needing vacuum. The CB900C didn't, in
    fact it had a conventional manual ON/OFF/RES petcock in series with a
    separate vacuum operated valve mounted on top of the carbs.
    If you don't have a PRIme position on your vacuum petcock, a handheld
    Mityvac vacuum pump is the slick way to fill the bowls without making
    your starter motor work overtime. You may also be capable of sucking
    sufficiently to actuate the petcock by mouth...
    Mark Olson, Apr 20, 2007
  5. Agree absolutely. My Triumph 1200 Trophy started quicker and easier if
    I switched it to Prime (especially if it hadn't been used for a
    while). Ditto my old Z650, now disposed of.
    That CB900C system sounds like an absolute abortion, btw.
    I've never seen a vacuum tap without a Prime position, actually. I
    suppose there must be some somewhere....
    chateau.murray, Apr 20, 2007
  6. Ivan Vegvary
    Mark Olson Guest
  7. Ivan Vegvary
    Bruce Farley Guest
    There is not a prime position on Honda petcocks. A small amount of
    vacuum should be all that is needed. Of course the petcock could be bad.
    Bruce
  8. Ivan Vegvary
    oldgeezer Guest
    Bruce Farley schreef:
    Mine are a Honda VF400F's. They have ON, OFF, PRI
    ON=open when vacuum, closed when no vacuum,
    OFF=tap closed, independent of vacuum.
    PRI=tap open, independent of vacuum
    For the rest, the advices are correct. If you have a PRI
    position, then use that after your bike has been left
    alone for a long time and wait a few seconds to let the
    bowls fill up, else use ON and be aware that starting takes
    a while.
    Rob.
    oldgeezer, Apr 21, 2007
  9. Ivan Vegvary
    Ivan Vegvary Guest
    Thanks everybody for the sage advice. I'll use my hand vacuum pump and
    spill a little gas into the carb bowls prior to starting.
    Thanks again.
    Ivan Vegvary
    Ivan Vegvary, Apr 21, 2007
