Honda RFVC Cam and Head problems.
Discussion in 'Australian Motorcycles' started by ACH, May 18, 2005.
  1. ACH
    ACH Guest
    I heard alot of problems with the CAM's and HEAD's of Honda RFVC engines
    (sounds alot like problems Honda had with the early V4 engines 83 to
    86).
    What is the difference between a RFVC and standard Honda engine?
    I heard honda went back to the standard design after years of problems
    with the RFVC engines?
    What years and engines sizes were RFVC (250, 350, 500 and 600)?
    What should someone look for when buying a used RFVC engine?
    Can anything be done to help the problems with the CAM's and HEAD's of
    Honda RFVC engines?
    Anyother problems besides Cam and Head problems?
    What about the RFVC engine used in the 1987 Honda CBX 250
    (does it have the same problems as the XLs)?
    ACH, May 18, 2005
  2. I had a CBX250 with the RFVC engine - great little 4 valve single. If I
    understand correctly, earlier RFVCs had a problem with head cracking
    around one of the exhaust valves - but I've read that this was fixed by
    the time the CBX was released.
    RL
    Richard Lindner, May 18, 2005
  3. ACH
    Rod Bacon Guest
    My understanding of RFVC (Radial Four Valve Combustion) and the
    difference to the standard 4-valve of the day was the fact that the
    valves were angled radially around the bore.
    Imagine sitting the valves on 4 "corners" of a tennis ball (I know that
    tennis balls don't have corners, but i couldn't think of a better way
    to describe it) so they each point away from the centre of the bore in
    a sort of 45 degree angle.
    Most other 4 valves have the 2 inlet and 2 exhaust valves mounted
    parallel to each other, more vertically. I had an XR250 (84) with RFVC.
    I cracked the head between the 2 exhaust valves.
    Rod Bacon, May 19, 2005
  4. ACH
    J5 Guest
    that was the twin carb models
    not enough meat in the head
    solved by going to the single carb in later modes
    J5, May 19, 2005
  5. ACH
    glitch1 Guest
    "Rod Bacon"
    I cracked my head ON the exhaust valve
    pete
    glitch1, May 19, 2005
  6. Rudge Four Valve Copy
    Alan Pennykid, May 19, 2005
