Honda VTR coolant boiling ?
Discussion in 'Australian Motorcycles' started by Phil S, Feb 13, 2007.
  1. Phil S
    Phil S Guest
    Recently on two days over 37 degrees when stopped at the end of a trip
    the coolant from the overflow bottle on my Honda VTR 1000 overflowed (I
    suspect it boiled from the temperature from the surrounding engine).
    There was no problem with the radiator and it didnt boil over into the
    overflow coolant tank. . I think it is purely from the location of the
    coolant reservoir between the cylinders of the engine. Has anyone elso
    had this problem.
    Phil
  2. Phil S
    Nev.. Guest
    What makes you think the water in the plastic bottle external to the
    engine would be hotter than the water inside the engine where all the
    heat was being generated?
    Nev..
    '04 CBR1100XX
    Nev.., Feb 13, 2007
  3. Phil S
    Phil S Guest
    No water escaped from the engine / radiator. The coolant tank has an
    overflow hose at the top with nothing to stop it escaping. I am only
    guessing at this stage though.
    Phil
  4. Phil S
    justAL Guest
    I believe Nev is trying to say.
    It came from the radiator....ie. It was doing it's job.
    justAL
    justAL, Feb 13, 2007
  5. Phil S
    Phil S Guest
    No it didnt come from the radiator. The coolant bottle emptied. The next
    day I had the bike serviced and the radiator was still full. Surely if
    it had come from the radiator its level would have dropped. The Honda
    dealer had no real answer.
    Phil
  6. Phil S
    justAL Guest
    So you're saying it was pissing out of the overflow?
    Can you put a figure to that? 150ml, 500ml?
    How much was in it to start with?
    It can still leak out of the overflow and not present a significant change
    in level.
    Just because there's a puddle of fluid under your bike that's 2 feet square
    doesn't mean that what's left has dropped below the minimal service level
    justAL
  7. Phil S
    Phil S Guest
    In 4000 km of travel lost no coolant. Two v hot days and lost whole of
    contents of coolant reservoir. Only observed between 1-2 square feet of
    fluid on each of two days when stopped. Some could have escaped during
    slow travel before stopping. Temperature gauge was within normal limits
    at all times.
    Phil
  8. Phil S
    Dale Porter Guest
    I'm yet to own a single vehicle, car or bike, that doesn't have some coolant come out the overflow pipe on really hot days.
    Bear in mind that the coolant will heat up when the engine is switched off before cooling down.
    Dale Porter, Feb 13, 2007
  9. Phil S
    Nev.. Guest
    It's a sealed system with only one overflow point. When the engine
    overheats, the water expands from the radiator into the coolant overflow
    tank, the plastic bottle. When that is full it overflows. i.e.. When
    you see the overflow tank overflowing, it means that the cooling system
    has overheated. When the engine cools, it will draw the overflowed
    water back into the radiator from the overflow tank. With a cold
    engine, take the radiator cap off. If there is no water in the overflow
    tank it probably means that the radiator will need topping up too. If
    there is water in the overflow tank and the radiator is full it means
    that probably a small amount of water overflowed, probably need to get
    the cooling system checked out. If there is water in the overflow tank,
    but the radiator is not full, you REALLY need to get the cooling system
    checked.
    Nev..
    '04 CBR1100XX
    Nev.., Feb 13, 2007
  10. Phil S
    Beefhooked Guest
    So what your saying Nev is that water expands when heated?
    Interesting...
    Beefhooked, Feb 13, 2007
  11. Phil S
    The answer should've been "that's 'cause it sucks it back in when it cools".
    That's what the "overflow" is for: it hold the extra that doesn't fit in the
    cooling-system when it's all expandified.
    When it's coolificated again it sucks some back in (otherwise it'd collapse
    your radiator)
    Clem
    Clem
    "If I don't answer you, it's because I believe my point has been made in the
    current post or others on the subject or that the points of argument
    presented are illogical." ..... Toosmoky
    Knobdoodle, Feb 13, 2007
  12. Phil S
    Eh?... The WHOLE contents of the reservoir?!!?
    It's not much of a reservoir if it didn't keep some in "reserve" then is it!
  13. Phil S
    It also expands when cooled below zero!
    [cue Twilight-Zone music]
  14. Phil S
    Nev.. Guest
    It must. How else could a pressure cooker work?
    Nev..
    '04 CBR1100XX
    Nev.., Feb 13, 2007
  15. Phil S
    Make sure that your thermo fan is coming on, and possibly check that
    your thermostat and temp sender are working correctly.
    Also, how many km has the engine done? I started to get similar
    symptoms from my GPX250 at about 120,000km when the rings were getting
    worn.
    BT Humble, Feb 13, 2007
  16. Phil S
    Toosmoky Guest
    Not since I replaced the water pump that had no vanes left.
    (Thanks to the mech that cleaned the running pump with a screwdriver...)
    Toosmoky, Feb 13, 2007
  17. Phil S
    Shep© Guest
    Shep©, Feb 14, 2007
  18. Phil S
    Shep© Guest
    Ditto.I think there is a fault in the temp sensing system and or the
    bike,"IS" overheating.I'd suspect a stuck or partially stuck
    thermostat for starters.
    Note:Most Honda/bike thermostats are stock parts and can be bought
    from local high street auto discount shops for way less than
    Honda/bike makers charge.Take thermostat into shop and ask(Don't tell
    them what it's for ;-)
    Shep©, Feb 14, 2007
  19. Phil S
    sharkey Guest
    Hi Phil, as the coolant heats up it expands a bit and pushes some out of
    the radiator into the coolant overflow tank. When the coolant cools down
    again, it contracts and the radiator slurps coolant back out of the overflow
    tank.
    -----sharks
    sharkey, Feb 14, 2007
  20. Phil S
    I thought pressure-cookers worked by preventing boiling by limiting the
    expansion.
    i.e. It still gets hotter (and expands) it just doesn't turn to steam.
    Knobdoodle, Feb 14, 2007
