Honda XR 650 L 1994
Discussion in 'Motorcycle Technical Discussion' started by Mr Matt, Aug 9, 2003.
  1. Mr Matt
    Mr Matt Guest
    Just picked up the bike. How can I make it run better? Smog pump removial?
    What is the proper jetting set up for it? Pops while slowing down. Can and
    are their baffels in the exhaust that can be removed? Thank you, Mr Matt
  2. Mr Matt
    opietaylor69 Guest
    Honda XR 650 L 1994
    Group: rec.motorcycles.tech Date: Sat, Aug 9, 2003, 1:26am (EDT+4) From:
    (Mr Matt)
    IMS sells a smog pump removal kit. It won't make it run better, but it
    will stop the popping on decell. Stock, the carb is pathetically
    lean. I run 55 slow and 158 main jets. Vacuum slide holes drilled
    out to 5/32. Snorkel removed from top of airbox, K&N air filter. It
    becomes a whole different beast with these mods. The baffle is tack
    welded in, on the top and bottom. The welds can be cut, but there is
    no advantage to removing the baffle. Just more noise.
    opietaylor69, Aug 9, 2003
