HondaSGX50 Sky clutch
Discussion in 'UK Motorcycles' started by Bill, Nov 2, 2009.
  1. Bill
    Bill Guest
    Honda SGX50 Sky:
    Hi all
    Has anyone ever worked on one of these toys. My daughter has one and it
    recently went into the shop to have a new drive belt fitted. They told her
    the clutch roller bearings were a quarter worn. Why they couldn't have
    checked with her while they had the engine covers off and done the job then
    is beyond me. Money in the bank I suppose. Anyway, my question is, do I
    need any special tools to remove the clutch. We may as well fit new rollers
    and the clutch friction discs while at it. trouble is I live 70 miles away
    so don't want to be messing about going back and forth for tools!
    Also, Haynes don't seem to do a model specific manual. is the Haynes moped
    manual worth getting?
    Thanks for any advice.
    Bill, Nov 2, 2009
  2. Bill
    Simes Guest
    Ermmmm...
    Doesn't this mean that the shop said they were three quarters unworn?
    Would you replace your tyres when they were a quarter of the way through
    their life?
    Simes, Nov 2, 2009
  3. Bill
    why not use the other 75% first?
    wessie, Nov 2, 2009
  4. Bill
    Bill Guest
    Which was exactly my first reaction when she told me. However she is a
    woman, she's panicking and giving me earache. It's easier to just change
    the bloody things for a quiet life!
    Bill, Nov 2, 2009
  5. Bill
    Extract £25 from her "for parts". Ride it "to a mate's who has the tools"
    that just happens to live in a pub. Spend £25 on a couple of pints and a
    steak dinner. Ride it home "fixed".
    wessie, Nov 2, 2009
  6. Bill
    I bet they're not talking about the roller bearings. They may well be
    talking about the rollers, these are service items and should really
    have been replaced with the belt. The rollers usually have a minimum
    worn diameter which will be specified in the manual. Although you'd
    usually replace them when they wear 'a bit flat'.
    You have to be a bit careful when stripping and rebuilding the belt /
    clutch / variator on an automatic. The strength of the swing arm depends
    on the case bolts being torqued correctly, also there the belt can only
    be fitted one way round... and there is an order you have to do things
    in or the front pulley nut comes undone after you've got it back
    together and running.
    Getting the haynes moped manual will tell you about all of these things.
    Muck, Nov 2, 2009
  7. Bill
    Simes wrote:
    Simes - when rollers wear they wear unevenly and make the clutch
    engagement very erratic, which in turn gives the belt a hard time. A
    quarter worn isn't too bad for now, but they'll need doing very soon or
    the clutch will be come impossible to live with
    Lozzo, Nov 2, 2009
  8. Bill
    Beav Guest
    You'd make a wonderful father you would.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 3, 2009
