|Honeymoon's over
Discussion in 'UK Motorcycles' started by Pip Luscher, Oct 31, 2006.
  1. Pip Luscher
    The Tuono's clutch slave cylinder has developed a slight weep.
    It's not bad, so today I thought I'd take it to work for the first
    time in a few weeks.
    Bastard wouldn't start, would it? I'd been living under the illusion
    that since it has no alarm, the battery wouldn't go flat.
    I'd forgotten that the clocks draw current.
    So I spent a merry five minutes trying to balance the bike on a gravel
    slope near enough the front of the car that the jump leads would
    reach, the battery being on the wrong side of the car, of course.
    I also had to get a jump start coming home: twenty-five minutes
    doesn't charge the battery enough for a cold start, it seems.
    I also found that the headlights are *way* out of adjustment, but at
    least I'll have a good view of any Countryside Alliance beasties that
    I'm about to squash.
  2. Why?
    The Older Gentleman, Oct 31, 2006
  3. Pip Luscher
    Why?[/QUOTE]
    To keep the clock (as in time) running, and the memory up. The memory
    keeps the various trip meter functions and set-up, like kph/mph and
    shift light (bloody thing defaults to kph and the shif light at
    6000rpm, which is exactly where the engine hits the real power).
    It's a bastard when it loses it 'cos I have to go through the
    rigmarole of resetting everything manually, and it does this every
    time the engine kicks back or hesitates on the starter.
    A planned mod, when I find a tuit, is to put a schottky diode in
    series with the clocks' permanent 12V feed, and a wodging great
    capacitor on the clock side of it. This *might* cure the reset
    problem.
  4. To keep the clock (as in time) running, and the memory up. The memory
    problem.[/QUOTE]
    <Thinks>
    Not a Windows product, is it?
  5. Pip Luscher
    problem.
    [/QUOTE]
    fit a Hawker Odyssey[1] battery: after my OE battery was 3 years old the
    voltage would drop below the ABS computer's fail threshold when cranking
    the engine. Apparently, the AGM construction results in a lower voltage
    drop compared to conventional batteries. They are less likely to go flat
    when unused for some time too: this seems to be my observation as I have
    not used my Optimate in 18 months. Well, except for the time I left the
    parking light on...
    http://www.odysseyfactory.com/
    [1] or Westco from http://www.motorbikebatteries.co.uk/
    wessie, Oct 31, 2006
  6. Pip Luscher
    ts Guest
    Considering that a silver oxide cell can power a watch for more than 3
    years[1]; there might perhaps be other reasons the battey drains?
    [1] insert alternative examples of battery-driven clocks as relevant
    ts, Nov 1, 2006
  7. Pip Luscher
    (ts) wrote in :
    It's Italian so that's a given.
    wessie, Nov 1, 2006
  8. Pip Luscher
    Dan L Guest
    Pip Luscher tossed off:
    Welcome to the club. My shite-old-Hyundai slave cylinder gave up on
    Thursday, in the rush hour in Bracknell. Popular I was not.
    Is it possibly fucked?
    Good work, keep it up
    Dan L
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Nov 1, 2006
  9. wessie wrote
    And get yourself a cheapo solar panel from Maplin to keep it topped up.
    Very eco friendly and years ahead of the fashion.
    steve auvache, Nov 1, 2006
  10. Pip Luscher
    Clutchless changes. Not that difficult.
    platypus, Nov 1, 2006
  11. Pip Luscher
    ts Guest
    Even worse combination, Italian bike in damp, cold, Atlantic climate . .
    ts, Nov 2, 2006
  12. Pip Luscher
    Well, you'd have thought so; I will check the current draw and the
    battery condition. maybe it simply is a buggered battery.
    Don't forget though that watches and bike instruments are rather
    different applications; there's little obvious point in adding a low
    current clock/memory circuit if there's a 17AH battery and charging
    system bolted on. It would mean either adding an external clock/memory
    chip, which adds expense, or the clocks' own microprocessor would have
    to have a low-power RTC/memory retention mode, so a special chip might
    be required. Maybe such chips are readily available, mind.
    Another point is that a sports bike designer probably has other
    priorities than his creation being left unused for a few weeks.
    The nice thing about my Guzzi is that it draws _no_current at all when
    parked and it will generally start easily after weeks without use.
    Pity the charging system has proven so unreliable...
    Pip Luscher, Nov 2, 2006
  13. Pip Luscher
    My gixxer (with clock) would happily hold charge for up to three
    months at a time.
    As should the TL. I suspect your battery's shagged.
    _______
    Ace, Nov 2, 2006
  14. Pip Luscher
    Just checked it: almost exactly 2mA at the battery if my elderly
    moving-coil meter is to be believed.
    That's not enough to explain the flat battery in the weeks that the
    bike has been unused, though. Looks like it's 10AH nominal capacity,
    so allowing 20% (this is a wild guess) of the nominal capacity to
    actually start the bike, that's still almost six months.
    The battery is currently on the Accumate, so I'll check it when it's
    done. Oh, and the charging system, of course.
  15. Pip Luscher
    I got one of those for the last car, whose battery kept going flat due
    to infrequent use.
    The panel plugs into the cigarette lighter, which was fine except that
    the socket was disconnected when the ignition was off.
    On the new car, the same applies, with the bonus that when the panel
    was plugged in, the alarm/central locking refused to work.
    I will, tuits being available, make a rain-proof box for it and bolt
    it to the shed, so it can charge a car battery for lighting.
  16. Pip Luscher
    Dan L Guest
    platypus tossed off:
    Indeed, would have been a lot easier had it been a company car too.
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Nov 3, 2006
  17. Either prob easily cured by a dedicated socket under the dash wired to
    the battery.
    Grimly Curmudgeon, Nov 3, 2006
  18. 2mA isn't a lot, but I've found on numerous cars/bikes that a battery
    when flattened by a smallish draw over weeks or months is definitely
    adversely affected for future use even if it seems to charge up ok; ie,
    it's buggered when it counts, like in the cold mornings. You seem to
    get away with it once or twice, but more than that you're looking at
    replacing the bugger.
  19. Pip Luscher
    There have been similar problems on the latest BMW motorcycles: canbusses,
    common on cars for ages, are finding their way onto bikes. It's best to fit
    any charging device directly to the battery otherwise the CPU gets all
    confused and starts shutting down circuits it thinks are drawing too much
    current.
    wessie, Nov 3, 2006
  20. Pip Luscher
    AOL, I always have. If you want the power cut off with the ignition,
    just run a relay triggered off an upside feed with the main power rail
    straight to the battery. Appropriately fused of course.
    Hog, Nov 3, 2006
