Hot weather jacket
Discussion in 'Australian Motorcycles' started by Aurimas, Nov 14, 2006.
  1. Aurimas
    Aurimas Guest
    Can you tell me from your experience what kind of jacket is the best for hot
    weather?
    Also where is the best to look in Perth?
    Thanks
    Aurimas
  2. Aurimas
    Boxer Guest
    I use a BMW Airflow Jacket (other brands have similar types) and consider it
    to be a good choice.
    Look at your friendly local BMW dealer.
    Boxer
    Boxer, Nov 14, 2006
  3. Aurimas
    John Tobin Guest
    I have a Dri-Mesh jacket and swear by it. And I live in Cairns.
    yoda
    John Tobin, Nov 14, 2006
  4. <snip>
    2nd vote for Cairns, and this time with a Dririder RallyCross. Being
    6"6, I found the Dri-mesh jacket wasn't long enough for me. The
    RallyCross is a 3/4 length jobbie, and fits nicely. The arms are also
    longer than the equivilent sized Dri-mesh.
    By way of quality, I'm quite happy with it. I've had it a couple of
    years, and it's holding up really well. There have been some reports of
    the 1st "model" (of which mine is) having some quality problems, but
    I've never experienced anything. Allegedly those probs were fixed with
    the 2nd generation design ("Dual Sport" series, vs Off Road series,
    apparently). The only complating I have is with the velcro straps on
    the arms sticking to the mesh on the chest. The ol' "I've stuck myself,
    err, to myself" trick.
    Jessie-girl has a Dri-mesh, has had it for a bit longer than I've had
    the RallyCross, and it's also holding up well. Fits her well, and seems
    to be lasting well.
    Have a try of both, and see which fits you better. If you're of the
    longer and ganglier persuasion, the RallyCross would probably be the
    better bet.
    All that said, The BMW jackets do come highly recommended, even though
    I've never had the pleasure of one. I'd imagine that the cost of them
    would be higher, but for the allegedly outstanding quality, you may
    decide it's worth it.
    Thanks!
    Matto :)
    05 Sprint ST - an outstanding commuter bike, as it turns out!
    VelocityTheory, Nov 14, 2006
  5. In aus.motorcycles on 14 Nov 2006 15:28:49 -0800
    I have an old model Rjays mesh jacket, which I chose because it had
    red instead of black on the main areas that get the sun.
    It does make a difference.... The ones with black on the back and the
    top of the arms are hotter in direct sunlight.
    Zebee
    Zebee Johnstone, Nov 15, 2006
  6. Aurimas
    sharkey Guest
    Crash tested mine. Worked pretty well.
    -----sharks
    sharkey, Nov 15, 2006
  7. Aurimas
    Hammo Guest
    You know, I'd be interested to know how much you reckon it is. (temp
    difference i.e.).
    Hammo
    Hammo, Nov 15, 2006
  8. Aurimas
    Boxer Guest
    Do a lot of crashing do we?
    Boxer
    Boxer, Nov 15, 2006
  9. In aus.motorcycles on Wed, 15 Nov 2006 05:42:10 GMT
    Can't say in degrees, but the difference between the black one I
    borrowed and the red one I bought was definitely noticeable.
    Zebee
  10. Aurimas
    Kevin(Bluey) Guest
    I have the Dri-Rrider Rallycross ,the only problem I had was with the
    front zip.I had it replaced by the tailor at the RAAF base ,had no
    problems since.
    Still hot though at 41 c , even the airflow does not cool you down at
    those temps and the air feels like it super heated.
    Needless to say I didn't bother getting the winter liner.
    Kevin(Bluey), Nov 16, 2006
  11. Aurimas
    Boxer Guest
    Fill the pockets with ice.
    Boxer
    Boxer, Nov 16, 2006
  12. Aurimas
    Theo Bekkers Guest
    I don't think Zebee said it was an empirical measurement but yeah. I have an
    RJays jacket also which is yellow and red, with the lower halves of the
    sleeves black. Black clothing and helmets do feel hotter than lighter
    colours.
    You're the scientist, you do the empirical testing.
    Theo
    Theo Bekkers, Nov 17, 2006
  13. Aurimas
    I'll add a "me too" here as well.
    After I bought a black Shoei and did a few GP trips and ride-days in it I'm
    a white-or-silver-only man now.
    Knobdoodle, Nov 17, 2006
  14. Aurimas
    J5 Guest
    J5, Nov 17, 2006
  15. Aurimas
    Are you accusing me of supporting apart-hat?
  16. Aurimas
    Hammo Guest
    I have measured some temperatures and the variations with thin film coating
    materials with differing colours, pigments, polymers and their backings.
    Hammo
    Hammo, Nov 17, 2006
  17. Aurimas
    Fark that was quick!
    Theo must have some clout (what with him bein' in charge of aus.moto and
    all!)
  18. Aurimas
    Toosmoky Guest
    "Was that Clem? I thought it was Bibendum..."
    Toosmoky, Nov 17, 2006
  19. Aurimas
    sharkey Guest
    *applause*
    Just to make sure we've got one of each opinion, I ended up buying a
    mesh jacket with light-coloured bits because I reckon it helps a bit in
    summer, and a black helmet because I don't think it makes much
    difference! I think it's a matter of how much insulation is between you
    and the surface, mostly.
    The mesh jacket (DriRider Rallycross) didn't fall to pieces in the crash
    either, it must be a lot tougher than it looks. I can't really speak
    for my jeans, since my legs didn't hit the ground really, I was too busy
    sliding on my head and shoulder ...
    I'm pretty happy with how the Shoei did its job ...
    -----sharks
    sharkey, Nov 17, 2006
  20. Aurimas
    sharkey Guest
    I wonder if RiDE magazine ever tested it for motorcycle gear, they tend
    to do a lot of empirical testing unlike the local rags.
    On the other hand, you'd not get much of an effect out of the English
    sun ...
    -----sharks
