How do I lube a clutch cable.
Discussion in 'Motorcycle Technical Discussion' started by mike, Sep 30, 2007.
  1. mike
    mike Guest
    83 honda shadow vt500c.
    The clutch cable was making a squeaking noise, so I decided to lube it.
    Over the course of several hours, gravity managed to get a few drops
    of oil down the cable.
    Doesn't squeak any more, but I have a new symptom.
    Don't know exactly how to describe it. The friction changes over the
    range of movement sorta periodically.
    Now what?
    The cable won't come out of the sheath. How do I get something as thick
    as wheel bearing grease down there.
    It would be relatively easy to pull a vacuum on the bottom end, but will
    15PSI negative suck in grease?
    Or machine a clamp that covers the end with a Zerk fitting on it.
    I was gonna make the cavity big enough to enclose the knob on the end
    so I only have to seal one end.
    Should be able to get plenty of force that way.
    I did find such a clamp on the web, but it's designed for thin spray
    lubricants. No option for anything thicker.
    Should I be attempting a different lube? It's an old cable, but I really
    don't want to spend any more $$ on this thing than I have to.
    Ideas/tricks?
    Thanks, mike
    mike, Sep 30, 2007
  2. I use those little plastic bags that are used for bagging up coinage.
    Poke the cable through a hole in the bottom, seal the area around hole
    with some tape or a small cable tie, pour thin lubricating oil (or a
    mixture of oil and WD40) into the bag, and hang up the cable for 24
    hours to let it work its way down the cable. Job done.
    The Older Gentleman, Sep 30, 2007
  3. mike
    mike Guest
    Before I put oil in it, the cable worked smoothly, just squeaked a little.
    Now the clutch doesn't pull smoothly. I'm afraid putting more oil
    or wd40 down it will make it worse. Don't I need something like grease
    in there to make the old cable work smoothly?
    mike
    mike, Sep 30, 2007
  4. Oh, just buy another cable.
  5. mike
    Nameless 1 Guest
    Somebody once wrote that modern cables have teflon sheaths and that
    oiling them just gums up the cable worse.
    But, what do I know? All my clutches have hydraulic release mechanisms.
    Nameless 1, Sep 30, 2007
  6. BMWs ~1980-1990 certainly do
    Dry powdered graphite perhaps ? It's also possible that
    there's a broken strand of wire. Suggest starting with
    a new cable and ask about lubing at the same time
    you buy the cable. If they don't know, you're probably
    using the wrong shop.
    Rob Kleinschmidt, Oct 1, 2007
