How do I measure carb fuel level from outside?
Discussion in 'Motorcycle Technical Discussion' started by mike, Jul 28, 2004.
  1. mike
    mike Guest
    1983 Shadow VT-500C
    How do you check the fuel level in the carb
    without taking it off?
    I wasn't able to get a good pix of the fuel,
    so I'll have to describe it.
    Here's a pix of the carb:
    http://nm7u.tripod.com/homepage/carb.html
    Note the black cross with center near the mating
    line of the bottom piece.
    Imagine a plastic tube hooked to the bowl
    drain and running up the vertical black line.
    the fuel level rises to the level inside the carb.
    This level is represented by the horizontal black line.
    So, now I know the level of fuel in the carb.
    But what should it be? Is there a known outside
    reference point that can be checked against?
    It's a real pain to take 'em off to check the inside
    measurement. And 20 year old plastic floats bend and warp
    and absorb fuel, so I'm not completely comfortable that
    the recommended measurement point is reliable.
    Measuring the actual level from the outside should
    be accurate.
    Is there a reference point outside the carb?
    Thanks, mike
    Return address is VALID.
    Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
    Bunch of stuff For Sale and Wanted at the link below.
    HP200LX 10MB + MODEM + LEATHER CASE
    Sony Digital Camera
    Compaq Aero floppy,ram,battery.
    FT-212RH 2-meter 45W transceiver.
    Toshiba & Compaq LiIon Batteries, Test Equipment
    30pS pulser, Tektronix Concept Books, spot welding head...
    http://www.geocities.com/SiliconValley/Monitor/4710/
    mike, Jul 28, 2004
  2. mike
    Page Guest
    Get a clear piece of tubing about 8-12" long that you can fit inside the
    screw hole in the bottom of your float bowl (Float Bowl drain). The
    tube needs to be big enough to seal the hole when you shove it inside.
    Shut off your fuel feeding the carb. Take the screw out of the hole.
    Let it drain out to empty. Put the tube into the hole. Raise the end
    of the tube so that the top of the tube is above the carb. Get a magic
    marker and mark a line at the top of the float bowl seam and the carb body.
    Release the fuel petcock and let the fuel fill the float bowl. The fuel
    will also fill the clear tube. Mark where the fuel stops in the tube
    with your magic marker. If you have done it right, measure the
    difference between the two marks. You should have amount your bowl is
    filling from the top of the bowl. The distance should be in your
    service manual. Too much check your float or bend the float tab to make
    it shut the needle valve sooner, check the bottom of the needle valve to
    make sure it is sealing.
    To do that, turn the carb upside down and put about 10psi suction on the
    fuel feed. If it leaks air, replace the needle valve.
    Too little bend float tab the other way. Your service manual should
    outline the specifics for your bike.
    Hope this helps.
    Page
    '01 FXDWG, NTXNS
    "Happy Hour" starts one twist of the throttle past neutral!
    Remove the 123 to reply.
    Page, Jul 28, 2004
  3. mike
    mike Guest
    Thanks for the response. I understand about the plastic tube...done
    that. Fuel level in the tube is easy.
    I don't understand about the other mark relative to the carburetor.
    Notice from the picture that the bottom cover to carb seam
    is not horizontal.
    http://nm7u.tripod.com/homepage/carb.jpg
    The distance specified in the manual is perpendicular to the carb body,
    not the angled position of the fuel when it's mounted.
    Even if it were perpendicular, the distance is for the float bottom.
    The float must "sink" in the fuel enough to displace enough fuel
    to support it's own weight plus the weight of the float valve.
    What am I missing?
    mike
    Sony Digital Camera
    mike, Jul 29, 2004
  4. If it were me, I think I'd try to get new floats before I
    wasted any time fighting with the old ones.
    Rob Kleinschmidt, Jul 29, 2004
  5. mike
    Tostada Guest
    Not sure about your bike, but in my shop manual, the measurement they
    give is for the fuel level, not for the float bottom. Having the carb
    tilted adds a wrinkle, but the principle is the same: the fuel level has
    to be high enough for the pick-up tube to get enough fuel at full
    throttle, but not so high as to overflow into the manifolds.
    I'm finding your explanation a little hard to follow--can you give us
    the exact wording from your manual? If the distance measurement is truly
    perpendicular to the carb body/float bowl seam, then you need to get out
    the protractor, and just make a mark on the carb.
    As well, my manual specifies checking with the bike running, as the
    level goes down a bit then.
    Are you sure the levels are wrong? I've read that 'Carburetor is a
    French word for "Leave it alone".' ;)
    Tostada, Jul 29, 2004
  6. mike
    mike Guest
    the protractor, and just make a mark on the carb.[/QUOTE]
    A picture is worth a zillion words
    http://nm7u.tripod.com/homepage/carb2.jpg
    Since they don't specify an angle or a position along the width of the
    carb, perpendicular is the only direction that makes any sense.
    I only have experience with a dozen bikes or so, and the dimension has
    always been perpendicular.
    Yes, it is possible to take it all apart, measure all the parts, do some
    geometry, weigh the parts, calculate the displacement required to
    support them and come up with a fuel level in the carb.
    I was hoping there was an answer already out there is cyberspace.
    This is just an aside. I have no idea if this is my problem. I posted
    the whole shaggy dog story under the thread about floppy vacuum
    cylinders. No suggestions so far.
    And that's exactly why I'm asking before I mess with it.
    Bottom line is that the Shadow has what sounds like fuel
    problems and I don't know how to fix it. Swapping out the carbs
    and whole fuel delivery system didn't fix it.
    mike
    Sony Digital Camera
    mike, Jul 29, 2004
  7. mike
    Battleax Guest
    This is really the only way to set float levels, and this is the only
    mesurement you will find.
    You simply must remove the carb to do this, there's no other effective way
    to set the float levels.
    Unless you've replaced the float valve or the floats themselves it's
    unlikely they need adjustments.
    B
    Battleax, Jul 29, 2004
  8. mike
    Tostada Guest
    always been perpendicular.[/QUOTE]
    Yeah, it looks like they are specifying a dry level, with the carbs out,
    and their special tool. Haven't done one of these, although I've seen it
    in various manuals. I tend to agree with Battleaxe--the level is
    probably not out, unless the needle valve seat is worn.
    I saw that. The symptoms were so varied, it was hard to think of a
    simple cause.
    This would tend to rule out the carbs as the problem, no? You've checked
    the coils, high tension leads, etc.? I had a snowmobile that started
    running weirdly, and it turned out to be a coil that was failing and
    affected by temperature.
    Tostada, Jul 31, 2004
