Take a screen shot from my laptop?
ctrl + alt + prt scrn. then open up an email, or word document and ctrl + v to paste the screen shot in. Failing that, use your camera phone.
Should work. Try just using prtscr, which will capture the entire desktop not just the active window. Failing that, if using XP or earlier get ZAPGRAB - lets you grap triangular sections quickly.
Simon, I've always used CTRL+PrtSC on all of my OS - if you don't use CTRL then you are asking for the SysReq to be used instead.
Ive never used CTRL prtscr - occasionally use ALT prntscrn or prntscrn on its own. Does sysreq do anything these days? http://en.wikipedia.org/wiki/Print_Screen
To be honest - I have absolutely no idea! The last time I used that was donkeys years ago, and it wasn't on a windows-based system, I used to use it to log on twice so that I could check whether or not alterations I had made had worked. Is there actually a necessity for sys req anymore? -- Lesley Residing in the Capital of Culture 2008 CBR600FW Peugeot 206 S SBS#11 (with oak-leaf cluster) BOTAFOT#101A UKRMHRC#12 BONY#54P BOB#18
Lozzo wibbled forthrightly: I'd try resizing or saving it as a jpg it with a program like irfanview (www.irfanview.com) though, as it'll probably be a big file otherwise.
In linux, alt-sysrq is a key combo used to tell the kernel directly to do a few things, like unmount partitions, sync hard drives and hard reboot (among others)
