How light was the Trophy 500 Triumph?
Discussion in 'Classic Motorbikes' started by brafield, Sep 16, 2008.
  1. brafield
    brafield Guest
    Anyone settle an argument? Stuck in my memory is that Triumph's
    Trophy 500 in the sixties weighed a tiny 330lbs ----- my mate does not
    believe a 500 twin could be built that light.
  2. brafield
    Krusty, Sep 16, 2008
  3. The message
    You may be right, but I'm with your friend.
    IIRC, the Thunderbird was 8 lbs heavier than a Vincent big twin...
    Rusty Hinge 2, Sep 16, 2008
  4. ISTR the Guzzi V50, shaft and all, weighed about that.
    <Googles>
    Dry weight 160kg - 352lbs. And that with a shaft.
    The Older Gentleman, Sep 16, 2008
  5. brafield
    You don't RC - even the Lightning with its magnesium & aluminium was
    significantly heavier than that.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
  6. brafield
    brafield Guest
    Thanks for the quick and helpful reply. Crazy, that with 21st century
    advanced materials / miniaturization, and scientific product
    development, bikes have not become lighter.
    brafield, Sep 17, 2008
  7. Just how ignorant are you?
    Nowadays some 750-1000cc bikes weigh little more than that.
    The Older Gentleman, Sep 17, 2008
  8. brafield
    Kevin Seal Guest
    In message
    HBOL ©1974
    T100R 337lB 153kg
    T90 336lB 153kg
    5TA 340lB 155kg
    3TA 340lB 15kg
    Kevin Seal, Sep 17, 2008
  9. brafield
    If you look at power to weight ratio rather than engine size, they have
    effectively become much lighter. A modern 250cc enduro bike will run
    rings round a Trophy, & weigh around 260lbs.
    Krusty
    Krusty, Sep 17, 2008
  10. brafield
    They have, relatively. My ZX0R weights 386lbs, and yet produces 4 or
    5 times the power, and around twice the top speed. The forces
    generated when using this power and speed (together with the grip
    afforded from modern tyres) are many, many times greater than the
    Triumph had to deal with, and yet the weight is less than 15% higher.
    Champ, Sep 18, 2008
  11. brafield
    brafield Guest
    Okay, okay everyone, I was wrong, and ignored the power-to-weight
    thing. But we DO have some rather porky litre-plus bikes on the road
    ---. Put it another way, how many 1960's bikes weighed 550-600lbs?
    brafield, Sep 18, 2008
  12. brafield
    Roger Hunt Guest
    I've got a T90, which weighs 3cwt, three bags of coal.
    The way things are going will soon be worth less than three bags
    of coal.
    Roger Hunt, Sep 18, 2008
  13. Any number of Harleys.
    The Older Gentleman, Sep 18, 2008
  14. The message
    My AJS 38/2 *FELT* as heavy as that, but probably wasn't.
    Rusty Hinge 2, Sep 18, 2008
