How long can a motorcycle battery last?
Discussion in 'UK Motorcycles' started by The Older Gentleman, Sep 4, 2010.
  1. I only ask because I replaced the battery on the K this morning[1].
    The battery in it was utterlly dead - I knew that because it wasn't
    holding a charge for more than a day or two. When I pulled it out, it
    had plenty of electrolyte in it but the plates were sulphating badly.
    Anyway, it was a Delta, made in Germany. Not a brand I've ever heard of,
    and Google isn't much help either. Anyone know what brand BMW fitted as
    OE, back in the early 1990s?
    As the bike's a 1993 model, I really doubt it was the original battery,
    but it could have been the first replacement, in which case about eight
    or nine years between batteries sounds reasonable. The one in the Ducati
    lasted ten.
    [1] BMW build their bikes around the clutch and the battery, don't they?
    Remove side panels, lift up seat, remove ABS computer, remove engine
    management computer, remove steel strap that holds battery down, finally
    remove battery.
  2. The Older Gentleman
    snip>
    It's still only a 5 minute job so not really any worse than a lot of
    Japanese bikes.
    My ZX10R has to have the pillion seat pad removed, a small cover that
    fits between the two seat pads removed, the riders seat removed and I
    think you even have to lift the back of the tank to get the battery
    out.
    Andy Bonwick, Sep 4, 2010
  3. The Older Gentleman
    Pete Fisher Guest
    At least you don't need a paddock stand to accomplish it.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 4, 2010
  4. Suppose so. ISTR ShiteOld Boxers as being worse. On the K, the battery
    is situated underneath the main computer - I suppose (a) because it puts
    the battery as low as possible for the C of G and (b) it means that it
    the battery does leak, it doesn't leak into the electronics.
  5. Delta is a brand that Aldi sells for household electric stuff.
    I think the sandwich toaster I bought was Delta, and a few other bits,
    the knife-sharpener maybe. May not be the same company, of course.
    "delta battery germany" mainly returns links to US vets...
    Dr Ivan D. Reid, Sep 4, 2010
  6. The Older Gentleman
    SteveH Guest
    No, it's easy in a Boxer.
    You just have to know which size battery was fitted from new, as mine
    came with the high capacity job, but I ordered a normal one...
    SteveH, Sep 4, 2010
  7. The Older Gentleman
    boxerboy Guest
    The original on the SO R80RT lasted 19 years, its eaten 2 since
    because I don't use it enough and am too fucking idle to keep charging
    it. Totally self inflicted
    Boxerboy
    boxerboy, Sep 4, 2010
  8. The Older Gentleman
    I got 6 out of a /secondhand/ battery on the Guzzi - last Rob Hunter also
    lasted 6.
    MZ ES250 (Snorky) 6v battery lasted over 6 years - it was robbed off the
    Frankfurt machine.
    So that's four sixes.
    sweller, Sep 4, 2010
  9. The Older Gentleman
    ? Guest
    I once read an article in which the original owner of a small
    displacement 1960's Honda claimed that the original 6 volt flooded
    cell lead acid battery lasted 27 years...
    I hate to imagine devoting even the smallest amount of time on a
    regular basis to match that sort of "record"...
    ?, Sep 4, 2010
  10. The Older Gentleman
    OE in my 2000 bike was an Exide[1]. Lasted 5 years. Replacement Hawker
    Odyssey is 5 years old and still going strong.
    Are you sure it was Delta, as DETA is a brand owned by Exide
    http://www.exide.com/portal/server.pt/community/brands_community/212
    The battery could be OE but most likely a replacement from a BMW dealer[2]
    in the early noughties. There should be a date code somewhere.
    [1] Mareg is the other brand seen from the same era
    [2] I think all of their batteries have BMW branding now, probably to
    disguise that they are made in Shanghai rather than Hannover.
    wessie, Sep 4, 2010
  11. The Older Gentleman
    Rob Hunter normal lead-acid batteries are fine, but I wouldn't use
    their sealed gel batteries as they are proper poo.
    Lozzo
    Versys 650 Tourer, CBR600F-W racebike in the making, TS250C, RD400F
    (somewhere)
    they churn out)
    Lozzo, Sep 4, 2010
  12. The Older Gentleman
    Vibration isn't good for batteries
    wessie, Sep 5, 2010
