how long?
Discussion in 'UK Motorcycles' started by Andy Bonwick, Jan 13, 2007.
  1. Andy Bonwick
    Earlier today I collected from the post office a nice little black box
    with Power Commander 111 printed on it. How long until the weather
    warms up enough for me to want to spend some time in the garage
    fitting it?
    The big decision is do I fit it now and map it for the bike as it is
    or do I fit the carbon airbox straight away and pay a visit to the
    bloke who knows and get those extra horses liberated before summer?
    You can never have too much power and I've heard a rumour that
    Kawasaki strangled the 10R in the first 3 gears but a bit of tampering
    sorts that out in no time at all.
  2. After serious thinking Andy Bonwick wrote :
    It is warm in my unheated garage, it was a balmy 13 deg C at lunch time
    today. I know, because I was out there putting in additional power
    sockets and air line outlets in shirt sleeves.
    Harry Bloomfield, Jan 13, 2007
  3. Such a good feeder ...... no ... resist......
    Brownz \(Mobile\), Jan 13, 2007
  4. Andy Bonwick
    It'd probably be about that temperature in our garage if I shut the
    door to block out the wind and put a fan heater out there for an hour
    before I started. The problem is that I'm a lazy bastard who didn't
    get out of bed until this afternoon and I've got a 260 mile drive
    tomorrow afternoon ready for work on Monday so I need excuses to put
    the job off.
  5. Andy Bonwick
    Tim Guest
    I expected better of you, it's not cold today. I spend some time in the
    garage today working on the Daytona.
    Tim, Jan 13, 2007
  6. Andy Bonwick
    Molly Guest
    I've read they restrict the opening of the secondary throttle butterflies.
    Some people have removed them and some have fitted a TRE which seems to fool
    the bike into thinking it's in sixth gear thus keeping the secondaries open.
    Quote...."If you remove the air box you'll notice that there's two sets of
    throttle blades UPPER & LOWER. The lower ones are completely controlled by
    your right wrist. The Upper one are ECU controlled. The ECU sees fit to
    limit the amount of throttle you can use at any given time. By simply
    removing the Blades ONLY and leaving the rest of the system intact the ECU
    thinks it's still doing it's job, but now you're in control of the amount of
    throttle being used. It does you no good to open the throttle completely up
    with the lower set if BIG BROTHER (ECU) is actually the one that controls
    how much air is entering the motor. This system is the first steps in FLY BY
    WIRE complete ECU controls. The future will probably NOT be as easy to fool
    the ECUs on these things. Our right hand won't control much more than a
    desire to speed up. The ECU will have the final word and that probably won't
    be what we want when we want it. (BE CAREFUL NOT TO DROP ANY OF THE SCREWS
    WHEN YOU DO THIS!!!!!!!!) "
    see: http://www.bikeland.org/board/viewthread.php?FID=19&TID=24500
    I'm still fumbling my way around the 10R power thing.
    It will be interesting to see what your bike makes after the mods.
    NB: This is what I've read and I have no proof that it works or not.
    Molly, Jan 13, 2007
  7. Andy Bonwick
    Sounds identical to the one I was already thinking of. Has Keef got
    his new toy yet because my airbox is identical to the one fitted in
    his and I was going to bribe him to let me post the box to him and
    then fit it in his garage before Slick gets loose on it or I spend
    ages in Slicks workshop fitting it before he does the important bits.
    I reckon letting Keef have a lap on mine after fettling will be enough
    to sway his decision making process and Janice is easily bought with
    flowers and groveling.
  8. Andy Bonwick
    The secondary butterflies are going, end of story. I've got a TRE
    lying around somewhere that needs splicing in but apparently the PC
    does enough without it.
    I'd already been told to bin them when I fit the airbox but Slick's
    the bloke to give the details. Someone else we know has a full
    superbike spec 10R prepared by Slick and part of ,y plan is to pull
    his bike apart and see what's what iyswim.
    snip>
    I want 170+ at the back wheel on Slicks dyno. He reckons it's
    achievable without engine work so why not do it?
  9. Champ, a couple of questions if I may.
    Do you know if the ignition is retarded in the first three gears like
    the GSXR1000 or is it just a secondary throttle thing.
    Who are the best people to get the front forks sorted on the ZX10R?
    Thanks.
    eric the brave, Jan 14, 2007
  10. What plans have you got to match the suspension to the 170BHP?
  11. Andy Bonwick
    The suspension is fine once you go away from the standard settings.
    I've got a decent damper on it and I don't use cheap tyres.
    Andy Bonwick, Jan 14, 2007
  12. OK, I thought you still had the STD shock. What did you fit?
  13. Andy Bonwick
    Where did I say I'd changed the shock? Change the settings, that's
    all. There'd be no point in me telling you how my bike is set up
    because you probably weigh a bit more than me and the one thing I've
    always bitched about with the bike is the suspension being a bit of a
    **** to get right.
    I just took the bike to a stretch of road I know very well and kept
    playing with one thing at a time until the bike felt ok for me. It's
    probably still well short of what someone with a clue could do to it
    but as long as I can ride it then I really don't feel the urge to
    tamper with it again.
  14. Ok, fair enough. Thanks.
  15. That's why I asked. I didn't hear you say you changed the shock, so I
    didn't know you hadn't. Have fun, The sun is out, I'm going for a bimble...
  16. Andy Bonwick
    Molly Guest
    Bloody hell, that's serious power.
    Akrapovic website are showing 163.9 at the back wheel for the stock 06 and
    165.4 with their end can fitted.
    http://www.akrapovic-exhaust.com/main/catalog/products-catalog.htm
    The 05 is showing 158.4 in stock form and 161.8 with their end can. I can't
    find a chart with the butterflies removed though.
    Molly, Jan 14, 2007
