"How stuffed am I?"
Discussion in 'UK Motorcycles' started by Milo Thurston, Apr 26, 2005.
  1. Can anyone diagnose the problem that might cause the
    following symptoms?
    1. "rough" sounding engine
    2. low oil level
    3. a bit of white smoke from the exhausts after running for a couple
    of minutes.
    4. Engine cut out when I got to work due to 2 - it
    was fine when I checked it at the weekend, though.
    It looks pretty nasty to me (piston rings?) and I was wondering
    roughly how much the bill for this one might set me back.
    Thanks.
  2. Milo Thurston
    flash Guest
    £750 to £752
    flash, Apr 26, 2005
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, flash
    Look, if you can't give an accurate figure, just butt out. OK?
    What bike is it?
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Apr 26, 2005
  4. Milo Thurston
    Anywhere between around £30 for a 50cc 2T to several hundred for a
    Brough Superior. Or to put it another way, it's a little hard to say
    without knowing what bike it is!
    Krusty, Apr 26, 2005
  5. Sorry - I was a bit rushed and forgot to add that.
    Triumph Trident 750, 1992.
  6. Milo Thurston
    Loz H Guest
    I wouldn`t immediately think of rings, oil usually burns bluish rather than
    white.
    Check your water for oil, it might be a blown head gasket.
    Someone remind me, the `92 Trident is water cooled innit?
    Loz H, Apr 26, 2005
  7. OK - thanks.
    Is that likely to be expensive?
    It is indeed.
  8. Milo Thurston
    Krusty says...
    I heard a scooter dealer quoting a customer 450 quid for a top end
    rebuild of a Vespa ET4 yesterday. Robbing ****.
    Lozzo, Apr 26, 2005
  9. Milo Thurston
    50 quid for parts & labour, 400 quid for the shame of having to touch a
    Vespa - seems reasonable to me.
  10. Milo Thurston
    It's a diesel, and it's fine.
    platypus, Apr 27, 2005
Similar Threads
Loading...
