How to get silicone offa my visor?
Discussion in 'UK Motorcycles' started by Simon Wilson, Feb 11, 2011.
  1. Simon Wilson
    Simon Wilson Guest
    I gave my visor a good clean the other day but when I took the pinlock
    thing off it left behind some of the silicone bead. Any ideas how to get
    it off without melting/scratching the visor?
  2. Simon Wilson
    Could try bunging it in the freezer overnight to see if the silicone
    will just crack off when frozen. Might be worth paging Cane on FB.
    Krusty, Feb 11, 2011
  3. Simon Wilson
    ginge Guest
    maybe leave it soaking in hot soapy water overnight.
    It certainly won't do any harm so there's nothing to lose in trying.
    ginge, Feb 11, 2011
  4. Simon Wilson
    Simon Wilson Guest
    Yeah - tried that. But of course it's 100% resistant since it's the same
    as bath sealant.
  5. Simon Wilson
    ginge Guest
    Ahh, I was thinking it might work itself between visor and bead ok.
    Uhmmm... WD40?
    ginge, Feb 11, 2011
  6. Simon Wilson
    Nah, not even cellulose thinners will clean silicone ime, it's evil
    stuff. Best way I've found for getting it off baths/sinks is slice it
    off with a razor blade, but I suspect the curve of a visor rules that
    out.
  7. Simon Wilson
    Beav Guest
    I hope it's a different silicone sealant they use around baths (it's not)
    and that it isn't affected *too* badly by a bit of warm soapy water.
    Except time and hope:)
    Beav, Feb 11, 2011
  8. Simon Wilson
    ginge Guest
    Given the silicone around pinlocks is normally bonded to the insert
    only thenit will have likely only become attached to the visor with
    continued pressure, can't see how it'd have properly bonded that way.
    ginge, Feb 11, 2011
  9. Simon Wilson
    Tim Downie Guest
    Well you could try this.
    http://www.amazon.co.uk/dp/B003ZUXQ...de=asn&creative=22206&creativeASIN=B003ZUXQLW
    Of course you'd have to test it on a small area first. Other than that,
    careful scraping with a razor blade is your best bet.
    Tim
    Tim Downie, Feb 11, 2011
  10. Simon Wilson
    Simon Wilson Guest
  11. Simon Wilson
    Simon T Guest
    I have used that once on a bath - seems to work but still had to cut
    the excess off first.
    Not sure what it would do the visor though.
    Simon T, Feb 11, 2011
  12. Simon Wilson
    geoff Guest
    There is a "stuff" you can get from somewhere like RS called silicone
    remover, I've got some somewhere, but I've never tried it
    type "RS components" into google and the "silicone remover", it's a 'kin
    long link, so I didn't post it
    Yeah, silicone's a bugger to get off anything, including glass
    geoff, Feb 11, 2011
  13. Simon Wilson
    geoff Guest
    "Usually dispatched within 3 to 5 weeks."
    geoff, Feb 11, 2011
  14. Simon Wilson
    Beav Guest
    Just roll the stuff off with a thumb. then follow it up with lighter fluid.
    Beav, Feb 12, 2011
