how to give striped metal a smooth finish?
Discussion in 'Motorcycle Technical Discussion' started by vasco, Aug 30, 2005.
  1. vasco
    vasco Guest
    Hi,
    In restoring my bike I started with the goal of making it run and
    ended up going a bit overboard, disassembling what a big part of it to
    remove rust and give it a thorough cleaning.
    Both sides of the engine covers and the top parts of the mufflers
    (near the engine) were filled with rust and corrosion and I ended up
    using a rotary wire brush on my drill to remove the rust and, of
    course, the chrome/polish came along with it. It is still shiny, but
    now it has this matte shine that looks better than all the corrosion
    and rust (I am still yet to decide on whether this was a good
    decision), but...
    I would like, if possible to, at least make it a bit smoother or
    shinier, but I can't find any information on this kind of repair except
    to have it plated by a pro, something my budget does not allow.
    Any suggestions on how to smooth the metal, or at least on how to
    protect it against future corrosion? Right now it's bare metal exposed.
    Any ideas appreciated,
    thanks,
    Vasco
    vasco, Aug 30, 2005
  2. vasco
    Don Fearn Guest
    In the past, I've polished aluminum to a high sheen by going through
    progressively finer wet-and-dry sandpaper from 330-grit up to
    2000-grit, followed by finer and finer polishes, finishing with
    Simichrome polish and then wax. It leaves a gloss that I like better
    than chrome, but that requires periodic polishing and waxing to keep
    it that way.....
    -Don
    Don Fearn, Aug 31, 2005
  3. Don,
    I have experimented with wet vs dry sandling and it seems the dry works
    better. Is that your experience as well?
    I have yet to find a way to really duplicate the brushed finish on Hondas
    but I am getting closer. I really would like to spray a high temp clear
    coat on the aluminum parts but haven't found anything labelled high temp.
    I don't want to waste time and money on a clear coat to find out it turns
    yellow in a month or two. Do you have any recommendations on clear coat?
    I know enough to NOT use a water based finish. All of the ones I tried
    really suck as they don't dry clear.
    pierce
    R. Pierce Butler, Aug 31, 2005
  4. vasco
    Don Fearn Guest
    No. When sanding aluminum I sand wet, with a steady stream of water to
    wash away the sanding dust.
    No. From above: ". . . finishing with Simichrome polish and then wax."
    -Don
  5. Maybe that is what my problem has been. Not enough water.
    I thought you had gone the clearcoat route at some point in time and then
    went sans clear coat.
  6. vasco
    bhalicki Guest
    I polished my swingarm a while back and found wiping with kero first,
    then sanding wet worked quite well. The kero stops the paper sticking
    and gives a smoother finish. I've also heard that soap works quite
    well, haven't tried that one though. I started with 600grit to get the
    scratches out, then worked my way back to 1500grit, which gave a mirror
    finish.
    Ben.
    bhalicki, Sep 1, 2005
