how to push start my gpx250
Discussion in 'Australian Motorcycles' started by john smith, Dec 24, 2004.
  1. john smith
    john smith Guest
    Hello all.
    Stalled my GPX250 the other day and couldn't get it to start again.
    I've spoken/typed about this problem before and it was suggested I get the
    valve clearences adjusted. I have had this done by my bike mechanic friend
    but it seems to have not fixed the problem.
    Either he hasn't adjusted them right, or I'm burning valves quickly (done
    2000kms) or there is some other problem. suggestions welcome.
    Anyway that's not what I'm here for. In my effort to get it started I
    thought I might try a push start it to see if that would work. Only it will
    only go into first. How do I push start this bike?
    Thanks.
    Gavin
  2. john smith
    John Littler Guest
    Push the gear lever the other way and put it into 3rd. Or push it in
    neutral then jump on and kick it in third (usually the easiest way if
    you're on your own and you have a hill available)
    JL
    John Littler, Dec 24, 2004
  3. john smith
    Uncle Bully Guest
    First gear is fine. I had a flat battery for about week, and was push
    starting my GPX no problems.
    Uncle Bully, Dec 24, 2004
  4. john smith
    GB Guest
    If it's the same gearbox as the ZZR JL (and chances are,
    it is) it won't go anywhere other than first when it's
    sitting still. By design. Dunno if it will go into third
    when it's being pushed along but.
    G
    GB, Dec 24, 2004
  5. john smith
    methanol Guest
    We found the best way to get my friends GPX going was to start pushing it
    while it was in neutral then click it down to 1st but keep the clutch
    disengaged for about 10 secs then pop it...
    methanol, Dec 24, 2004
  6. Push starting is fine in first gear, so long as your clutch isn't worn out.
    As for the not starting, how hot is it? My GPX started overheating once, and
    was a BASTARD to start when it was cooked.
    James Mayfield, Dec 26, 2004
  7. john smith
    Nev.. Guest
    He'll have fun trying to push it along if he's putting it in gear while it's
    standing still. Even with the stupid kawasaki gearbox[1] once it's rolling
    along in neutral he should be able to select any gear he likes.
    Nev..
    '03 ZX12R
    [1] they obviously never considered that when it's pissing down rain and I
    have up to 180hp on tap I might actually want to choose 2nd or 3rd gear while
    stationary.
    Nev.., Dec 27, 2004
  8. john smith
    john smith Guest
    I think my 1st gear push starting technique needs work. I didn't try too
    hard because I didn't want to look like a dickhead. If you say it can be
    done I'll try that next time.
    GPX runs with the temp needle at about a quarter. If your stopped at the
    lights it never gets to half way. normal?
    gavin.
    john smith, Dec 28, 2004
  9. john smith
    This is fine if you've got a pusher or a hill to get up some momentum but
    if you're stuck with just you on a flat road you need to use first.
    I usually try and get whatever geographical advantage I can from the
    chamfer of the end of the driveway or the camber of the road.
    I sit ON the bike and just paddle it forward with my legs and then pull in
    the clutch, kick it into first, raise my arse 6" off the seat and as I bang
    my arse back down I drop the clutch and jiggle the throttle and then pull
    the clutch back in the instant it fires.
    Mind you; this takes a bit of co-ordination and will only work for bikes
    that otherwise run fine but are lacking volts.
    If the bike is fouled up from a long period of inactivity or is in a poor
    state of tune then get a few pushers and use third!
    Good luck,
    Clem
    Knobdoodle, Dec 29, 2004
  10. john smith
    ****; if I was pushing you and you waited 10 seconds you'd better hope it
    starts 'cause I'd bash you if I caught hold of you!!
    Clem
    (Actually; I don't think I could even keep running for 10 seconds!!)
  11. john smith
    John Guest
    Doing it that way.... how many bent sub-frames have you ended up with?
    Johno
    Beer mate? - the real stuff, not the soldering flux shit you drink.
    John, Dec 29, 2004
  12. No kidding.
    Who are you replying to, numbnuts?[/QUOTE]
    He's not - he's playing around in some lame-arse google-ad-spamming
    usenet-to-webforum website. He's go no idea he's actually on the
    aus.motorcycles newgroup and so even if he did care about usenet
    etiquette or conventions, he wouldn't know to apply them in the "forums"
    he thinks he's using.
    My advice?
    [aus.motorcycles]
    Score: -9999
    Organization: www.talkaboutmotorcycles
    (season and stir suitably for your newsreaders scorefile syntax)
    big
    Iain Chalmers, Dec 30, 2004
  13. john smith
    IK Guest
    No kidding.
    IK, Dec 30, 2004
  14. john smith
    If it's cold, wet and brown I'll drink it!
    Clem
    Knobdoodle, Dec 30, 2004
  15. john smith
    Conehead Guest
    Hmmmm. Clem the old-fart drinker
    Conehead, Dec 30, 2004
  16. In aus.motorcycles on Thu, 30 Dec 2004 15:16:08 +1000
    A pint of Yarra water for Mr Doodle...
    Zebee
    - who will say nothing about the possibilities inherent in
    refrigerators
    Zebee Johnstone, Dec 30, 2004
  17. john smith
    SmeeR11S Guest
    Actually Zebee we do get some of our drinking water from the yarra.
    (upper yarra Dam)
    SmeeR11S, Dec 30, 2004
  18. Try switching to reserve...
    Postman Pat
    Pat Heslewood, Dec 30, 2004
  19. john smith
    I think it's the Yarra that runs through where Leo is at Warburton and it
    looks pretty nice and clear up there.
    Is there a mud-works closer to town?
    Clem
    Knobdoodle, Dec 31, 2004
  20. In aus.motorcycles on Fri, 31 Dec 2004 21:10:48 +1000
    The Yarra is famous for being "too thick to swim in and too thin to
    plough"
    Zebee
    Zebee Johnstone, Dec 31, 2004
