How's this work, then?
Discussion in 'UK Motorcycles' started by Rich B, Nov 30, 2007.
  1. Rich B
    Rich B Guest
    Bear with me here.
    Just got a pair of paddock stands to make things easier with the bike. It's
    the first time I have used a front stand, and I can't work out how it should
    fit. It's got two triangular brackets on pivots on the upright arms, each
    having two pins about 2" apart pointing inwards with nylon sleeves,
    presumably to protect the paint on the fork legs. It looks as if the pins
    should locate below the fork legs, but whichever way I do it the fork ends
    are pretty unstable. I've tried it with one pin below the leg and one in
    front, when the bike slides off backwards as it goes over-centre, and with
    one below and one behind, when I can just about get it to stay up, but it
    looks marginal. I can get it stable if I wiggle one pin from each side into
    the end of the axle, but then there isn't enough lift to get the tyre off
    the ground. Pinch bolts are fore and aft, so are no help in locating the
    pegs.
    The only way it will hold the forks up reasonably if I kind of balance the
    fork legs with both the pins underneath, but it is not positively located
    and looks as if it would slide off easily. The width of the fork leg is
    almost exactly the same as the distance between the pegs. I certainly
    wouldn't dare to take the wheel out with it in that position.
    So, FOAKs, what am I doing wrong?
  2. Rich B
    YTC#1 Guest
    Is he ? You poor bastard
    YTC#1, Nov 30, 2007
  3. Rich B
    Rich B Guest
    Sucking his keyboard for inspiration, YTC#1 typed:
    Heh. I was kind of expecting that ...
  4. Rich B
    christofire Guest
    Works for me too.
    christofire, Dec 1, 2007
  5. Rich B
    MikeH Guest
    I now have this image of Bjork and Benny holding up a bike amid the
    sound of silver spandex tearing.
    MikeH, Dec 1, 2007
  6. Rich B
    MikeH Guest
    OK, it should be Bjorn and Benny but Bjork would add a funny
    lopsidedness to it.
    MikeH, Dec 1, 2007
  7. Rich B
    MikeH says...
    Maybe I should nickname my front paddock stand 'Bjork' because that
    makes the front wheel sit lop-sided.
    Lozzo
    Triumph Daytona 955i SE
    Suzuki SV650 K3
    Honda CBR600 F-W
    Suzuki GSX-R750L
    Yamaha SR250 SpazzTrakka
    Lozzo, Dec 1, 2007
  8. Rich B
    Rich B Guest
    Sucking his keyboard for inspiration, Gavsta typed:
    Ah, OK. That's what I thought. I shall have to persevere.
    Possibly - it wasn't all that expensive. Now that I know how it *should* be
    working, I can possible make some mods to it that will help it to fit the
    fork bottoms better.
    Shall look at that too. Not keen on putting the weight of the bike on the
    exhaust, but I'm sure some arrangement with wood blocks will do the trick.
    Thanks for the reply.
    Rich B, Dec 1, 2007
  9. Rich B
    Rich B Guest
    I've just been for a look, and the underneath of the Ducati is a bit of an
    asymmetric mess of one-sided pipes, oil filters and the like. Could easily
    make up a wooden jig to spread the load to the less bendy bits, though.
    Rich B, Dec 1, 2007
