HP printer problems
Discussion in 'UK Motorcycles' started by Lozzo, Dec 18, 2005.
  1. Lozzo
    I have an HP PSC1210 all in one printer-scanner-copier thingy. Up until
    three days ago it worked fine at all it was meant to do. I tried to scan
    a couple of pics of my kids the other day and it won't have it, says
    there is a communication problem between the unit and my pc. So I
    unplugged the unit and uninstalled the software then reinstalled it as
    per the instructions. I got the message that the drivers are loaded
    correctly, but the pc can't complete the device set-up. Now it won't do
    anything except copy remotely from the pc, it won't scan and won't
    print.
    Anyone got any ideas as to what needs sorting and how to go about it
    please?
    Lozzo, Dec 18, 2005
  2. Lozzo
    muddy Guest
    I take it you removed the software/drivers from windows setup? Did you
    run the HP remove tool in the hp folder before you reinstalled? I seem
    to remember it causes problems if you don't
    muddy, Dec 18, 2005
  3. Lozzo
    muddy said...
    I didn't, but I will when I try again tomorrow. I can't be arsed now.
    Lozzo, Dec 18, 2005
  4. In uk.rec.motorcycles, Lozzo amazed us all with this pearl of wisdom:
    Tried doing a system restore?
    That's what happens when I can't be arsed fiddling about either.
    Whinging Courier, Dec 18, 2005
  5. Lozzo
    Whinging Courier said...
    I wouldn't know how
    Lozzo, Dec 18, 2005
  6. In uk.rec.motorcycles, Lozzo amazed us all with this pearl of wisdom:
    Start|All Programs|Accessories|System Tools|System Restore, restore my
    computer to an earlier time.
    With any luck you should have some System checkpoints on there. Click on
    the calendar with the highlighted dates on it on a day you think the
    computer/scanner was working properly.
  7. You may need to remove all references from the registry manually of the
    printer , then reload the installation software , had this problem on my
    old 1100c
    and that was the method recommended by hp support
    They also recommended uninstalling antivirus software (especially Norton )
    Steve Robinson, Dec 18, 2005
