HTF do I put an ART can back on my SV?
Discussion in 'UK Motorcycles' started by Angus Spangle, Jan 30, 2004.
  1. Hello peeps and knowledgeable bodies[1]
    My recently acquired SV650s came with an ART can. An OEM can had been
    refitted by the dealer, and I want to put the ART can back on, and I
    need a bit or bits[2].
    The original exhaust system was chopped 5 or 6 inches upstream of the
    original can. The replacement OEM can has the 5 or 6 inches of length
    (it may even be the original can), which is attached by a connecting
    tube that fits inbetween the perforated inner wall and the outerwall
    of the exhaust of both the upstream & downstream bits of the exhaust.
    The whole thing is secured/sealed by a big wide jubilee clip around
    the join. Let's try some awful ASCII section drawing...
    ____H____
    where <underscore> "_" is the outerwall, "H" is the jubilee clip,
    <minus> "-" is the connecting tube, <apostrophe> "'" is the perforated
    inner wall. (Note this is just top half of a section drawing.)
    Now the ART can that I have has a protruding "flange" that protudes
    about 1.5 inches out of the upstream end of the can and directly out
    in a straight line. Hence "bit" missing between exhaust and can.
    a) What's the missing "bit" called?
    b) Is this 5 or 6 inch chop a standard way of fitting a [ART] race can
    for SVs?
    c) Is this "bit" a standard part?
    d) If so, where would I get one from? ART? LBS?
    e) If not, WTF do I do? WTF would I get the correct "bit" fabricated?
    Apologies if all this is available on the wu-wu-wu. Goggle didn't help
    much, and WTF does ARTs site not have a "skip intro" ARRRGGHHH! (And
    no useful info.)
    [1] Well, knowledgeable bodies really, but hello to other peeps
    nonetheless.
    [2] Sorry dudes, that's as close a technical term I can think of.
    TIA
    Spangle.
    SV650s
    NC30
  2. Angus Spangle
    dwb Guest
    Completely flummoxed by the rest of your post, but yes cutting them here is
    standard on SV's for most 3rd party exhausts.
    dwb, Jan 30, 2004
