I'm the owner of a AMW Spirit custom 5 speed motorcycle with a S&S 1400 cc engine. Recently the following problem occurs: When the engine is warm (approx after 60 min of riding) the clutch handling becomes quite heavy. Even shifting into gears becomes very tiresome. However, when the motor is cold the gear shifting and clutch handling is all the different, even easy. I've checked all fluid levels and also attempted to bleed the hydraulic systems, with no positive results. I've even checked the oil pump to see that it's working correctly. Could I receive any advise or suggestions how to deal with this problem?
