I appear...
Discussion in 'UK Motorcycles' started by Beelzebub, May 9, 2005.
  1. Beelzebub
    Beelzebub Guest
    .... to have some semblance of brakes now. Spent yesterday fettling and
    fiddling, examining all the joints, calipers, pistons, hoses et. Culminated
    in the simple act of tying the master cylinder in elevated position, cable
    tying lever, rocking bike from side to side and tapping all the joints and
    hoses.
    This morning snipped off the cable tie to find that I had a nice firm lever.
    It's settled back in a bit again, so I'm repeating the process tonight.
    <relieved>
  2. Beelzebub
    'Hog Guest
    Tying the lever back overnight does usually help. Bleed, tie back, bleed
    again. Short of finding a shop with a pukka pressure bleed system who is
    prepared to flush your system right through ya just have to keep at it.
    Does it have goodridge lines? and even if it's the older type some new
    microbores might help if nothing else improves feel.
    Did Loz replace the seals at the master cylinder as well as the
    callipers.
    I had a K100LT which I was *sure* allowed air back into the system by
    some devious unexplained route. Never did get it completely sorted.
    'Hog
    'Hog, May 9, 2005
  3. Beelzebub
    Yes, he did. He replaced the dust seals, the fluid seals and the
    master cylinder seals. The system was bled vertically, horizontally
    and every other fucking way. It was fine. The amount of fluid it has
    had through it doesn't bear thinking about.
    Pip, May 9, 2005
  4. Beelzebub
    Pip says...
    Ditto. Dunno what, if anything, I did wrong. When I left here, Pip will
    attest to this, they were absolutely excellent and the lever had about
    1/4 inch of play at most.
    Lozzo, May 9, 2005
  5. And it's now back to that after repeating the process last night.
    Don't think for a moment you did owt wrong, suspect it's just needed a
    bit more after a few runs. It had slowly degraded to the stage of the
    lever only firming up approximately 1" from the bar. There's no fluid
    escaping anywhere so my guess is microbubbles.... or that you've
    surreptitiously taken out a massive insurance policy on my life.....
    Beelzebub@Work, May 10, 2005
  6. Beelzebub
    'Hog Guest
    Yes I knew this last bit. It's really weird how something as simple as a
    hydraulic system can vary this way. As Bee says, microbubbles, but how
    do the fuckers get back in there. It has to be past a seal somewhere,
    moisture boiling up or a new quantum migration model. Perhaps Ivan could
    turn that new toy of his on this problem?
    'Hog
    'Hog, May 10, 2005
  7. Ahhh, but I don't think the microbubbles get back in as such, I think
    what happens is that they're already there but originally so tiny that
    they're not noticeable. However, over a period of usage, they migrate
    and gang together forming bigger bubbles, which become very noticeable.
    Of course, I could be talking rubbish!
  8. Beelzebub
    'Hog Guest
    Hmm do different size air bubbles behave differently? good question.
    Over to Ivan again really.
    It could be gamma ray strikes through the liquid causing ionisation and
    possible gas bubble generation.
    'Hog
    'Hog, May 10, 2005
  9. Well, the bigger the bubble, the more of a void it will
    present,increasing apparent compressibility. In an incompressible
    fluid, if you have lots of teeny-tiny, independent bubbles , the
    compressibility of each tiny bubble has much less of a total effect,
    than if they were clumped together in one big bubble.
    Badly explained, I know, but I know what I mean.
  10. Beelzebub
    'Hog Guest
    Except all fluids can be compressed of course ;o)
    So what do we think tying back the lever overnight acomplishes?
    'Hog
    'Hog, May 10, 2005
  11. Beelzebub
    We don't fucking ask, of course. It just fucking works, OK?
    Pip, May 10, 2005
  12. Beelzebub
    'Hog Guest
    Inquiring minds need to know!
    I suspect it compresses the fluid slightly creating an environment that
    the nanobugs don't like and they migrate temporarily into the fork oil.
    'Hog
    'Hog, May 10, 2005
  13. Beelzebub
    frag Guest
    'Hog scribbled:
    I recall on a Fiesta they had problems with the brake pedal always
    having loads of travel, after "fettling" it would be OK for a day or
    so, and then back to crapness.
    Turned out to be one of the front brake discs was not bolted on true
    (bit of grit underneath it), so as it rotated round it wobbled the pads
    in and out when the brakes were applied, causing the fluid to be pushed
    back into the master reservoir, causing lots of pedal travel (or having
    to pump the brakes at worst) when they were next applied.
    Took the garage bloody ages to find that one :)
    Dunno how likely that could happen to a bikes braking system with
    floating discs (or even semi floating). I suppose if the disc was
    warped it could have the same effect?
    frag, May 10, 2005
  14. Beelzebub
    frag Guest
    'Hog scribbled:
    Forces the bubbles to be absorbed back into the fluid, like carbonated
    liquid, innit?
    Hence shaking your bike vigorously will reduce performance of the
    brakes a lot quicker than riding it sedately.
    frag, May 10, 2005
  15. Beelzebub
    Beelzebub@Work says...
    It might have been down to the brake fluid I used. It was always clean
    new fluid stright from the bottle, but it was just average cheapo from
    the local car parts emporium. As a last resort I'd go for summat like
    Goodridge's own stuff to see if that makes a difference.
    Lozzo, May 10, 2005
  16. Beelzebub
    Champ says...
    Like I said, it's a last resort. I've done absolutely everything, new
    seals all round, new master cylinder seals, new Carbone Lorraine pads
    the fucking lot. The only things I haven't changed are the brake lines
    cos they are braided ones and I didn't use expensive fluid.
    Lozzo, May 10, 2005
  17. Beelzebub
    Champ says...
    You reckon?
    What makes you say that? They will bleed up fine then go back to where
    they were after a couple of days by the sound of it. If it was down to
    discs then they'd go back to previous form as soon as you start riding
    and using the brakes. There's no judder from the brakes either, so that
    rules out warping.
    Lozzo, May 10, 2005
  18. Beelzebub
    I had the same problem on the Tig (which has braided lines). Stapping
    the lever to the bars overnight would see it fine for a full day's
    riding, but no more than that. Castrol SRF cured it, but don't ask me
    why.
    Krusty, May 10, 2005
  19. Beelzebub
    Krusty says...
    May be worth a try with a decent brand off fluid, rather than the Comma
    stuff that's in it at the moment. Thanks.
    Lozzo, May 10, 2005
  20. Beelzebub
    I've never had a problem with that in the past but I have had bleed
    nipples and banjo bolt washers that were worn enough to allow air to be
    drawn in via the threads, but not for fluid to leak out.
    sweller, May 11, 2005
