I came a cropper
Discussion in 'Australian Motorcycles' started by Guest, Nov 17, 2005.
  1. Why Smee?
    Why must he suffer your penance?
    28 is not too low and I would be interested as to what you claim to be
    "ideal" an your rationale for it.
    Hammo
    Hamish Alker-Jones, Nov 18, 2005
  2. Guest
    Smee R1100s Guest
    Why do you care Hammo?
    I don't
    I gave my opinion.
    don't like it?
    Smee R1100s, Nov 18, 2005
  3. ----Clang----
    Do you have a problem?
    It is your opinion and a crap one, especially as you suggested that "it
    serves you right". That is a poor and lame thing to say.
    Some bikes do well to have a lower PSI on the rear. The friction created at
    that lower PSI creates a suitable pressure in the tyre.
    Hammo
  4. Guest
    IK Guest
    Sorry, Smee, but when I got the flat tyre between Mitta Mitta and Omeo
    on the way to the GP last month, I could only reinflate it to about
    12psi with the CO_2 cartridges in the repair kit, yet the back end
    didn't feel overly sloppy in the super-tight stuff between Anglers Rest
    and Omeo.
    IK, Nov 18, 2005
  5. Guest
    Shep© Guest
    They re-surfaced a roads near me(UK) and they left more ridges in them
    than as if it had been snowing and cars had made ruts in them.More
    like ruddy tram lines!!!!
    I avoid that road on my bike :/
    Shep©, Nov 18, 2005
  6. Guest
    sanbar Guest
    Anyone had problems like this?
    Weaving
    (http://www2.ee.ic.ac.uk/cap/cappp/projects/2/files/weave_0_65.avi) is a
    low frequency (2-3 Hz) oscillation of the whole vehicle[1]. It can
    become unstable at higher speeds with fatal results.
    Based on The control and stability analysis of two-wheeled road vehicles:
    * The weave oscillations damp out once the rider reduced the roll angle.
    * Tyre (tire) characteristics and inflation pressures are important
    variables in the behaviour of the motorcycle at high speeds.
    * From a stability point of view it is desirable to make the lateral
    stiffness as large as possible, with the possibility of an optimum value
    for the torsional stiffness of the rear frame.
    * Common levels of lateral stiffness at the wheel spindle deteriorates
    the wobble mode damping substantially with significant changes in the
    wobble frequency as well, and slight reduction in the weave mode damping
    at high speeds.
    * Lateral distortion should be opposed as much as possible by locating
    the front fork torsional axis as low as possible.
    * The largest contribution to the weave damping came from the cornering
    and camber stiffnesses and relaxation length of the rear tyre and not so
    much from the same parameters of the front tyre.
    * Amongst others, stiff frames, a long wheelbase, a long trail and a
    flat steering head angle were found to increase weave mode damping.
    * Degraded damping of the rear suspension, rear loading and increased
    speed amplifies cornering weave tendencies.
    * Rear load assemblies with appropriate stiffness and damping were
    successful in damping out weave and wobble oscillations.
    The only time I have ever experienced this is skipping a gear when
    braking heavily and the engine compression forces the back wheel into a
    semi-skid[2].
    -sanbar
    sanbar, Nov 18, 2005
  7. Guest
    sharkey Guest
    I've found, oddly enough, that flatter tyres tend to make the bike
    follow tram tracks (etc) more, so it could indeed be some combination
    of low tyre pressure and the asphalt repairs. Probably depends on
    the bike, too, the GS feels like a drunken pig at 12psi. (and a
    sober pig at correct tyre pressure)
    I don't think it's much of a case to, you know, sue someone or anything
    though since the falling off bit of it could have been avoided by either
    a) better tyre maintenance b) better riding technique or c) slowing
    down.
    -----sharks
    sharkey, Nov 18, 2005
  8. Guest
    john doe Guest
    don't people know that you don't "rear brake only" when road riding?
    guess not. no wonder he crashed.
    john doe, Nov 18, 2005
  9. Yep, every K100 I've ridden at speed (fast corners) with a worn rear shock.
    The wallow never seems to eventuate into anything nasty, but it's very
    disconcering till you learn to accept thats what the bike does. Mostly felt
    through the rear, the front still felt stable. Fitting a rear shock with
    adjustable damping like a Koni or better fixed it immediately. Never
    happened in a straightline like the .avi, only when leant over at speed.
    Al
    Alan Pennykid, Nov 18, 2005
  10. Guest
    Shep© Guest
    Dickhead.
    Shep©, Nov 19, 2005
  11. Guest
    Smee R1100s Guest
    And? what are you gonna do about it?
    Start another lecturing thread with psychobabble again?
    Not interested:p
    Not the zx12
    cheers.
    Smee R1100s, Nov 19, 2005
  12. Guest
    Smee R1100s Guest
    was it a zx12?
  13. Guest
    John Guest
    That's because GS can / is a drunken pig sometimes at PI - but we
    still like him ;)
    Beer mate?
    Johno
    John, Nov 19, 2005
  14. I do check my tire pressures before most rides of any distance or if the
    bikes' been sitting for a while
    I've got a couple of bikes registered at present and I've found that the
    correct pressure is much more critical on the bigger tyres e.g.. 170 than on
    the 120 (both rear sizes}
    28 psi on the larger tyre makes a lot of difference to my bikes handling
    {usually run 36} however the 120 can go down below 20 (usually 32} before I
    notice anything amiss
    Buy yourself a quality pressure gauge and a 12V super cheap pump and check
    your tires at home before each ride or once a week if you ride daily
    Oh and accept that your probably at fault in some way whenever you have an
    off and learn how to avoid that particular incident in the future.
    Cap. LT
    Capt.about lunchtime, Nov 19, 2005
  15. Guest
    IK Guest
    No, but it was a bike with a similar wheelbase and weight distribution,
    identical rear suspension layout and swingarm and rear wheel
    construction, running less than half the rear pressure in question
    without too much drama...
    IK, Nov 19, 2005
  16. Guest
    Smee R1100s Guest
    Interesting how different bikes handle with low tyre pressures.
    The beemer will not handle well with low tyre pressures, in fact it gets
    sloppy and wobbly.
    Must be different with different bikes
    I assume the zx12 would weigh considerably more than your little kwaka
    though.
  17. Guest
    IK Guest
    Wet weight of stock ZX-9R; 213kg.
    Wet weight of stock ZX-12R; 248kg.
    Stick me on a ZX9 and put someone like TB on a 12 and the two bike/rider
    combinations will weigh the same.
    IK, Nov 19, 2005
  18. Guest
    Smee R1100s Guest
    yes but will the bike behave the same if the rear tyre was underpressured?
  19. Guest
    IK Guest
    If the all-up weights were similar, what could cause them to behave
    significantly different?
    IK, Nov 19, 2005
  20. Guest
    John Guest
    I have heard that EVEN with the correct pressure in the tyres, the
    beemer will still not handle well... something to do with the water
    they use in the tyres for ballast?? ;0
    Beer mate?
    Johno
    John, Nov 19, 2005
