I *love* alarm installers - at least I got that sorted
Discussion in 'UK Motorcycles' started by Timo Geusch, Jan 1, 2007.
  1. Timo Geusch
    As I hinted in my earlier post to UKRMC the VFR has been suffering from
    an(other) annoying electrical problem for a while as the lhs indicators
    were on an extended holiday and would occasionally drop by.
    Finally made an attempt to get it sorted today. It required a bit of
    fiddling with cables but I finally traced the problem to a broken cable
    in the indicator loom. Of course it wasn't "just" broken, the guy who
    had removed the alarm from the bike (why?) had soldered the cables
    together in such a clever way that a clean break had occured and the
    whole thing was only held together by the heatshrink tube that had been
    used around it. Re-soldering was pointless as it would break there
    again - the cable was too long due to matey soldering in an extra
    length of cable; of course the extra strain had broken the soldered
    joint in the first place...
    Fortunately I had a similar connector in my box of electric trickery so
    I could just replace the little wire stub and the crimped connector in
    the block. Wahay. After about half an hour of tracing the wiring and
    fifteen minutes of swearing, I've got reliable indicators again.
    Next jobs, fit new front disks as the old ones are warped, put a set of
    bar raisers on and sort out the squishy front end. And then I may want
    to go and insure and tax the bloody thing again.
    Anybody got a front paddock stand I can borrow?
  2. Timo Geusch
    Dave Emerson Guest
    Maybe. Where are you?
    Dave Emerson, Jan 1, 2007
  3. Timo Geusch
    Ashford, Kent...
  4. *Waves*
    The Older Gentleman, Jan 1, 2007
  5. Timo Geusch
    Consider it borrowed then, thanks.
  6. It's designed for Ducatis.
  7. Timo Geusch
    It's designed for Ducatis.[/QUOTE]
    A trellis framed paddock stand?
    Andy Bonwick, Jan 1, 2007
  8. Timo Geusch
    How does it hold up the front end then?
  9. Timo Geusch
    deadmail Guest
    It has a small compartment to hold the spare spark plugs and the number
    for the AA stenciled on the side.
    deadmail, Jan 1, 2007
  10. Timo Geusch
    I tried to avoid being bitchy but you just couldn't resist could you?
  11. Timo Geusch
    deadmail Guest
    Absolutely not, I can't see a belt without punching below it, grabbing
    and twisting.
  12. Timo Geusch
    Single sided, perchance?
    Pip, Jan 1, 2007
  13. You utter, utter ****.
  14. The prongs fit into the bottoms of the fork legs.
  15. Timo Geusch
    Which should work on the Honda as well, unless Ducati uses really
    spindly fork compared to Honda, and I somehow can't see that happening.
  16. Timo Geusch
    Timo Geusch says...
    Probably for the same reasons I've removed the alarms from almost every
    bike I've ever had with one fitted - because alarms on bikes are shite
    and will always give you trouble.
    My ZX-9R alarm was going off at 2am and wouldn't turn off on the fob,
    simple solution was to snip the fucking alarm wires with a pair of side-
    cutters and remove the back up battery from the unit. Next morning I
    traced the loom back and soldered it all back to standard. I also ripped
    the alarm box out of my Thunderace and threw it in the skip at the Black
    Horse.
    I just know the Triumph's Datatool alarm will play up one day, but I'm
    ready for it and know what to do now.
    Lozzo, Jan 1, 2007
  17. Timo Geusch
    Well, I'm more of the "I'm not going to have an alarm in the first place"
    persuation - the salesweasel at Auntie Carole was about ready to have his
    head explode when I explained to him that no, I was not going to have an
    alarm fitted to the BMW (sorry), and *especially* not by one of their
    mobile guys.
    And herein lies part of the problem - soldering cables that are exposed to
    vibration isn't necessarily a good thing as they can break if you don't do
    it right. The bloke that played with the electrics/removed the alarm on the
    VFR couldn't. I was glad that it got away with a non-working indicator as
    it could've been worse. Like, turning off the engine while doing about
    50mph on the M20 like the other "professional" electric repair I've had on
    that bike.
    Aren't those things just plugged into a secret connector in the Triumph loom
    anyway?
  18. Timo Geusch
    Timo Geusch says...
    Oh that's right, just give the fucking game away, why don't you.
    Lozzo, Jan 1, 2007
  19. Timo Geusch
    FFS, those who nick bikes already know that. I mean, it's even been in
    *DiRE*.
  20. Timo Geusch
    But not as much trouble as not having petrol.
    sweller, Jan 2, 2007
