I suppose it had to happen eventually ...
Discussion in 'UK Motorcycles' started by Salad Dodger, Apr 17, 2011.
  1. I feel much the same way about fork oil. At least it's not corrosive to
    paint.
    The Older Gentleman, Apr 18, 2011
  2. Salad Dodger
    Salad Dodger Guest
    Apparently ( my word of the day), I need to clean the surface to be
    stuck with "rubbing alcohol" - Robert Dyas don't stock it - anyone any
    idea where, or is it an Ebay frenzy once more?
    Salad Dodger, Apr 19, 2011
  3. Salad Dodger
    If the 'surface to be stuck' is metal, use cellulose thinners,
    available from Halfords & probably any motor factor. White spirit
    would do the job too.
    Krusty, Apr 19, 2011
  4. Salad Dodger
    Ben Guest
    Boots. Surgical spirit.
    Ben, Apr 19, 2011
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    Rubbing alcohol is Septic for surgical spirit.
    Wicked Uncle Nigel, Apr 19, 2011
  6. Salad Dodger
    Salad Dodger Guest
    Ta.
  7. Salad Dodger
    Salad Dodger Guest
    Painted plastic - the chrome "accents" attach by double sided tape.
    I've just noticed I've been sent a driving lamp kit for an airbag
    model. Bother.
  8. Salad Dodger
    any alcohol will do - meths, ethanol or isopropanol. All are sold as
    "rubbing alcohol" according to wikipedia.
    wessie, Apr 19, 2011
  9. Low grade surgical spirit, or even IPA will do.
    If it's to make sure the surface is grease-free, just use meths.
    Grimly Curmudgeon, Apr 20, 2011
  10. Salad Dodger
    Or just use a citrus-based degreaser. Works just as quickly and well,
    much more pleasant on hands and nose, and greener too, if you're
    bothered by such things.
    Ace, Apr 20, 2011
  11. Salad Dodger
    Just use a bit of soapy water then. It's not like whatever it is will
    be covered in chain lube.
    I hate it when that happens.
    Krusty, Apr 20, 2011
  12. Salad Dodger
    Greene King?
    CT, Apr 21, 2011
  13. Salad Dodger
    Marstons is better
    wessie, Apr 21, 2011
  14. Salad Dodger
    For drinking or for cleaning surfaces?
    If the latter, then I'll bow to your superior knowledge on this one.
    CT, Apr 21, 2011
  15. Salad Dodger
    Both. Higher ABV for Marstons would make it a better cleaner.
    http://www.marstonsbeercompany.co.uk/our_brands/marstons/oldempire.asp
    The bottled version is one of my favourite ales to drink at home.
    Greene King IPA is weak, insipid stuff.
  16. Salad Dodger
    Of course!
    Ah, yes, I believe I've tried it on occasion. In fact, I need to get
    some ales on the way home tonight so if Tesco has it...
    True, but that makes it dead handy for all-day drinking sessions at
    Twickenham.
    CT, Apr 21, 2011
