I think I can safely say...
Discussion in 'UK Motorcycles' started by Timo Geusch, Apr 6, 2008.
  1. Timo Geusch
    .... that cleaning a bike while it's snowing sucks.
  2. Post corrected
    The Older Gentleman, Apr 6, 2008
  3. Timo Geusch
    What else is new?
  4. Ah.
    I can't be the only one...
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Apr 6, 2008
  5. Timo Geusch
    It wasn't snowing when I started.
    platypus, Apr 6, 2008
  6. Timo Geusch
    Dan L Guest
    As is fitting a set of braided lines in a draughty shed with a 1200w
    ceramic heater. What's even suckier is discovering that the last banjo
    bolt supplied (front master cylinder) is a fine pitch whereas all the
    others supplied were coarse pitch. Thank **** MPS are open until 3 on
    a Sunday.
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Apr 6, 2008
  7. Timo Geusch
    Dan L Guest
    You've got a nice smile and a cracking pair of tits Mark.
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Apr 6, 2008
  8. Timo Geusch
    Arrrrrgh. You can't just post this kind of vehicular porn without a
    warning.
    Oh well, I'm hoping that the next house will have a decent sized shed
    (small aircraft hangar would be nice) and hopefully not a neighbourhood
    association that sends the boys around if you keep your garage door open
    for a little longer than strictly necessary or fire up a slightly
    under-silenced bike or car.
  9. Timo Geusch
    That's what I figured. My ideas of the Land of the Free and neighbours
    that tell you when to rake the rock garden[1] don't quite gel.
    Same here - only problem is finding such a place that's now so far from
    civilisation that you can't get Internet access (and, erm, TV for the
    other half) without massive satellite dishes and yet far enough away
    from other people that the local kitty that keeps your property
    rodent-free is of the pale brown & weighs 200 pounds variety.
    Nevada's quite good for that sort of thing, the only issue being that
    for the kind of commute Ann & me would be likely to look at, I'd need a
    private pilot license. And given the winds over the Sierras, the commute
    to work might be "accidentally" interrupted by one finding Steve
    Fosset's plane.
    [1] Vegas - they're severely (and rightly) cutting back on the amount of
    water you're allowed to use for gardening and actually "recommend"
    against lawns.
  10. Timo Geusch
    Corrections corrected.
    _______
    Ace, Apr 6, 2008
