I think I'm fated to fail with electrical stuff.
Discussion in 'UK Motorcycles' started by Mo, Nov 18, 2006.
  1. Mo
    Mo Guest
    Now the colder weather is here I thought I'd buy a pair of Gerbing
    heated gloves. I soon realised they weren't working as advertised
    being lukewarm at best on a mild day, then they became intermittent
    cutting in and out during my commute.
    I went back to the shop where I bought them and thinking the fault
    ought to be either the cable that feeds up through the jacket or the
    cable attachment to the battery because both gloves were affected I got
    a replacement for the jacket feed because it was didn't need any
    disassembly. I checked it at the shop and the gloves were heating up so
    off I went. On the way home they stopped working again and now don't
    work at all.
    I called in at Maplins and bought a cheap multimeter to test the gloves
    and cabling. Got it home unpacked it and found it was DOA. So I took
    the multimeter back and got a replacement when I got that home I found
    that although it switched on, segments of the LCD wouldn't come on
    unless I pressed on the screen. Anyway I tested the lead from the
    battery, which showed 12V on the connector the Gloves both tested at
    about 11 Ohms each which would seem about right, I didn't test the
    continuity of jacket connector but I guess that's must be the problem
    although I find it surprising to get two defective connectors. Or is
    there some other explanation.
    Anyway I took the multimeter back and got a refund. Now back to the
    shop for a another replacement cable.
    Mo, Nov 18, 2006
  2. Mo
    mr p Guest
    If it's not working then take them back again, although it's hard to
    imagine how something so simple can fail to work, I bought two of
    those maplin meters some time ago, BOGOF - I wander if the one I have
    not removed from it's packet actually works from your experience!
    mr p, Nov 18, 2006
  3. Mo
    gomez Guest
    Is this the buy one get one free then lose two so buy another one get
    one free then lose one offer?
    gomez, Nov 19, 2006
