I thought 350 Morini clutches were meant to be dry.
Discussion in 'UK Motorcycles' started by Pete Fisher, Apr 6, 2011.
  1. Pete Fisher
    Pete Fisher Guest
    The Morini has been weeping a bit of oil from the clutch cover after a
    good run so I ordered some new clutch seals from NLM. Popped the cover
    off today to discover it was pretty much operating as a wet clutch. I've
    never seen so much oil in there before. If it hadn't been fitted with
    the WeeVee conversion (spacers under the spring housings to increase the
    load) it would probably have slipped like crazy.
    The WeeVee hex head spring nuts speed up the job instead of the usual
    slotted things and I was pleased to find my trusty clutch holding tool
    after nearly twenty years languishing in the special tools box (old
    plain plate bolted to a bit of steel flat stock).
    New cam belt next in readiness for Cadwell in June. I can't actually
    remember when it was last changed.
    | Pete Fisher at Home: |
