If *you* think that you've got a though restoration project...
Discussion in 'Classic Motorcycles' started by Timo Geusch, Sep 12, 2004.
  1. Timo Geusch
    .... a visit to the Mosquito Museum near Colney hatch kinda puts that
    back into perspective again.
    Like, trying to solve the problem of fitting two RR Merlins back into
    an airframe that you can't really move around, plus the engine
    mountings are about 2.5m of the ground. Makes refitting something like
    a Benelli Sei engine look like a walk in the park.
    They're also restoring one of the DeHavilland planes that took part in
    the England-Australia Airrace in (I think) 1934. With the paint sanded
    off it suspiciously looks like one of the balsa-and-plywood model
    planes some of my mates used to build (and crash). Only bigger. And
    some nutters flew that to Oz...
    However the fans of Brit bikes will be placated by the fact that not
    only British bike engines leak oil.
  2. Mosquitoes were taken off the flying list when the wooden airframes
    started deteriorating. IIRC they were plywood - laminated, with epoxy
    gluing the whole thing together.
    The DH racer was called the Comet. The Mosquito was really built using
    what they learned from the racer.
    Merlin engines are ace, no question. Mine Dew, the Daimler Benz 601 (as
    fitted to the ME109) was just as great an engine. I always have a
    suspicion that there are two reasons why it's not regarded as a classic:
    1. They gave it a number, not a name.
    2. It doesn't whistle and warble like a Merlin.
    The Older Gentleman, Sep 12, 2004
  3. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember
    (The Older Gentleman) saying
    something like:
    Probably fish glue, in those days. Or a horrible concoction of snot and
    horse shit.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Sep 12, 2004
  4. Nope, it was epoxy. First real use of the stuff, IIRC.
  5. Timo Geusch
    Steve Ashton Guest
    And, of course, it was on the losing team.
    I have a feeling it didn't cut out like the Merlin if you went from level
    flight straight into a dive. Something to do with fuel injection as opposed
    to carburettors. Not sure about that, try not to do it on my bike.
    Steve
    Steve Ashton, Sep 12, 2004
  6. Early Merlins did cut out from the effects of negative G on the carb,
    yes, while the injected DB engine didn't worry about it. Push the stick
    forwards on an early Merlin, and the engine stuttered, so you had to
    half-roll and then dive. A DB601-engined plane just went straight down.
    But by 1941 they'd cracked the problem on the Merlin.
  7. Timo Geusch
    Ian Morgan Guest
    They did a bit of a comparison on Robboe Coltrane's excellent Trains Planes
    and Automobiles show, talking to a German guy who had garage loads of the
    Messerschmitt engine. He reckoned it was superior because the turbo or
    supercharger (can't recall which) had variable boost, depending on air
    pressure, ones they stuck on the Merlin just had 2 stage boost. (Or am I
    thinking about the wrong engines?)
    Ian
    Ian Morgan, Sep 12, 2004
  8. I think you've got it right. IIRC the Merlin had a two-stage
    supercharger (not turbo) and the DB was variable.
    Where's Dodger or Weggy when you need them?
  9. Timo Geusch
    The Older Gentleman was seen penning the following ode to ... whatever:
    They are indeed plywood, covered in fabric. Fastest plane used in WWII
    up to about 1944, and relying on its speed alone. *No* armour plating
    at all.
    One of the blokes I talked to at the museum confirmed that there
    aren't any airworthy ones left - the last one belonged to BAe and
    disappeared in a showed of splinters at an airshow, leaving the crew
    dead. No-one's tried to get one airworthy again since then although
    appearantly a few people in Canada are (or at least were) trying to
    restore one to airworthy condition.
    Ah yes, DH-88 Comet, not to be confused with the later passenger
    jet. Like the ones shown here:
    http://www.pjcomputing.flyer.co.uk/comet/links.html
    Ooooh, and some 'merican has had a flying replica built. Nice.
    <wanders off and checks spec>
    How much fuel? FFS, that's a flying Molotov cocktail - I've seen the
    fuselage of the one they're currently restoring and it's not very
    big. How the hell did they manage to get 258 *gallons* of fuel stashed
    away in this plane?
    Although I must say I'd prefer the black & gold colour scheme used on
    another Comet in that race, piloted by a Mr & Mrs Mollison[1]. Judging
    by the B&W photos of it, it looked proper sinister.
    *sigh*
    I've never heard one running, and I'd really like to. According to
    NiceOldBloke, one of the two Merlins fitted to the prototype Mosquito
    is in good enough condition for RR to run it on a bench, but the other
    one's had it.
    Oh, and there may be two more reasons why the DB 601 isn't that much
    of a classic:
    3) Wrong country
    4) It worked and didn't leak oil :)
    [1] Mrs Mollison was slightly better known under the name Amy Johnson
  10. Timo Geusch
    .... using single-point FI like on your aunt's Metro. Although I think
    the rumours that suggest that the Metro was still using the same
    system were slightly exaggerated.
  11. Timo Geusch
    And what really amazed me was that they used the same construction
    principles on the Venom jet fighter. I didn't quite believe my eyes
    when I noticed that the paint on one of them was lifting and there way
    plywood underneath, but looking at another one - well, the nose
    section - that had the paint stripped off confirmed that it was indeed
    plywood.
  12. That's correct. The Vampire and Venom were jet fighters made (at least
    partially) of wood. Utterly incredible, when you think
  13. Indeed. The Metro's system was nowhere near as sophisticated.
  14. They gave the Luftwaffe a really hard time, not least because they had a
    low radar signature, being mostly wooden. The first semi-stealth
    aircraft?
    The LW never really got to grips with the Mosquito. They had nothing
    comparable. The nearest thing was the Junkers 88, itself a very fast and
    versatile aircraft, and by using nitrous oxide (seriously!) to boost the
    engines, they could just get a JU88 to fly high and fast enough to have
    a pop at the Mosquitoes.
    But the casualty rates in Mossies bore out the facts - you were quite
    likely to survive the war if you flew them. Very fast, very high.
  15. Timo had an ancestor working at R-R? Cool.
  16. Timo Geusch
    Andy Wegg was seen penning the following ode to ... whatever:
    That was the BAe one, correct?
    According to the bloke at the museum the one in Canada my not fly
    after all. Something to do with the fact that every time a 60-year old
    plane falls out of the sky, the requirements for restoration get
    jacked up.
    Nice. Oh to have the money...
  17. Timo Geusch
    "Comet"
  18. Timo Geusch
    Ancestor in Spirit, maybe. Although in that case, it may have been
    sufficient to push the engine past him and then check if anything
    broke.
  19. Timo Geusch
    You cnut :)
  20. Timo Geusch
    Not to mention the fatigue issue. I think if that hadn't happened the
    gubmint would've have started buying Boeing.
    Hard to say, even with 20/20 hindsight. And no-one knows if it had
    changed anything anyway, given that the world aircraft market is hard
    pressed to support the number of manufacturers we've got now, after a
    lot of them already went south.
