im a goose
Discussion in 'Australian Motorcycles' started by Graham, Jul 24, 2005.
  1. Graham
    Graham Guest
    I bought myself a new chain from mca in Sydney , went home and counted the
    links (twice) and still cut the damn thing off too short ! Had to go and get
    an extra joining link to fix it. Never having changed a chain myself , i
    thought that it would be simple enough to peen over the pins , but oh no ,
    its bloody near impossible. Anybody in Wollongong got a chain breaker/joiner
    that i could borrow? Otherwise im gonna have to buy the aforementioned tool
    , about $90 i believe. (then i'll have two - me and it :)
    Graham
    GSX750F
  2. Graham
    rockit Guest
    No it's not. You must be doing something wrong.
    Do you have someone holding a solid form of dolly at
    the back of the pin?
    I get my wife to hold the handle of a 3/4 drive socket
    lever. I put some cloth around the part that comes in contact with the wheel
    hub, so as not to cause abrasion
    there. Then lay on my side and tap away. Make sure that the plate is punched
    home first.
    I contemplated buying a riveter, and checked with my local bike shop for
    some advice on one, as I felt a bit guilty with what I was doing. They just
    do the same as me.
    Rockit
    rockit, Jul 24, 2005
  3. Graham
    Graham Guest
    snip
    Do you use a punch or some other object to actually peen the ends over , or
    just a hammer of some sort?
    I have'nt actually hit the new joining links yet i was practising on some
    other ones that i cut off the end of the new chain , but i couldnt burr
    them over, so i didnt want to risk the new ones.
    Graham
    GSX750F
  4. Graham
    Graham Guest
    Yeah something like that Nev , im not real sure exactly what i did wrong
    because i cut it on friday afternoon after 70 hours of work that week , i
    was tired and should have just done it on saturday after a good nights
    sleep. I've got the length and links right now, it will just have two
    joining links instead of one when i work out how im am going to fit them
    successfully. I learnt a lesson here ,dont do stuff like this when tired, i
    stuffed up a beautiful weekend weather's worth of riding.
    Graham
    GSX750F
  5. You some sort of mates of Hammos?
    Matt
    On 24/7/05 7:31 PM, in reference to
    42e36002$0$31987$,
    Hamish Alker-Jones, Jul 24, 2005
  6. Graham
    rockit Guest
    I started off trying to use a centre punch and didn't have
    any success.
    I use a reasonable sized ball peening hammer - the rounded end - it's made
    for that sort of purpose.
    You won't have much success in just trying to peen over
    the end of a pin, not being supported, it will probably bend, and I don't
    think that a flat headed hammer would
    suit..
    When the pin is rightfully fitted, that can't happen. The
    purpose of supporting it from behind is to remove the
    shock\load from the supporting sprocket tooth(s) and
    give some rigidity.
    It is important that the pin be properly splayed as your life might depend
    upon it if it were to come adrift.Because of the lip over which the o-ring
    goes, acting as a support, the
    plate won't be pushed down too tight. It's easy, you will know when it is
    right.
    Rockit
  7. Graham
    Graham Guest
    Thanks mate , ive got a ball peen hammer i'll give it a go
    Graham
    GSX750F
    Graham, Jul 25, 2005
  8. Graham
    Graham Guest
    I think i might be turning into a Matt !
    Graham
    GSX750F
  9. Graham
    Graham Guest
    Especially boring ones like mine Clem !
    Graham
    GSX750F
  10. Graham
    X-No-archive: yes
    You don't sound too bored yet Graham...
    Clem
    Knobdoodle, Jul 25, 2005
  11. Graham
    What you talkin about, Willis?
    (Who has fitted new chains to bikes in carparks in Brisbane, Adelaide,
    and Hall's Creek.)
    BT Humble, Jul 25, 2005
  12. Graham
    Nev.. Guest
    As they say in comedy... It's all in the timing.
    Nev..
    '03 ZX12R
    Nev.., Jul 26, 2005
  13. Graham
    Ah! You're referring to my CBR1000F camchain incident![1]
    Anyway, technically *that* ferchrissake moment occurred when I was on
    the road, not in the shed.
    [1] My memory has substantial holes in it.
    BT Humble, Jul 26, 2005
  14. Or the 500 on the road in a shed?
    Pisshead Pete, Jul 26, 2005
  15. Graham
    Nev.. Guest
    I wouldn't call a few sheets of corrugated iron roofing held up by a few bits
    of water pipe on the side of the Stuart Hwy 75km south of Pimba a 'shed'.
    Nev..
    '03 ZX12R
    Nev.., Jul 26, 2005
  16. Graham
    Moike Guest
    You would if you saw what passes for a 'shed' at my place!
    Moike
    Moike, Jul 26, 2005
  17. Graham
    What the...? Is it "Give-BT-A-Shellacking-O'Clock" AGAIN? ;-)
  18. Graham
    Graham Guest
    At least while thy're picking on you they've forgotten to bag me !
    Graham
    GSX750F
    Graham, Jul 27, 2005
  19. I havn't put a new chain on for ages so I got a new one but I can't see how
    to fit it.
    Brett
    R80
    Brett Danvers, Jul 27, 2005
  20. Graham
    Moike Guest
    You use a screwdriver to undo the little cover plate on top of the
    switch block. The chain and sprocket are joined. If you are only
    replacing the chain, prepare for some fiddly dremel work, otherwise
    simply release the nipples, lift out the old chain, and drop the new one
    back into the same place first applying a suitable lubricant. Reattach
    nipples, replace cover, tighten screw and go.
    Moike
    (or did you mean the cam chain......)
    Moike, Jul 27, 2005
Similar Threads
Loading...
