In-line fuel taps?
Discussion in 'Classic Motorcycles' started by The Older Gentleman, Oct 11, 2006.
  1. The Z650, I've discovered, has a vacuum tap fitted that has no vacuum
    connection. I've yet to check to see if there's a blanked off vacuum
    point on the carbs. Early Z650s had ordinary fuel taps; later ones had
    vacuums, and I don't know whether the tap belongs to the bike.
    Discovered this when I removed the tank the other day, and petrol pissed
    everywhere, and no immediate means of turning off the flow.
    One option - a genuine Kawasaki manual tap from Z-Power. £50 plus VAT.
    Another - finding out if there's a vacuum point, buying a diaphragm
    repair kit, and sorting it out that way. Cost about £25.
    Simplest and cheapest option: an in-line fuel tap that I can just splice
    into the fuel line like this one:
    http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=
    LMA348
    Though I'd prefer something easier to operate. Any suggestions.
    Question - the Demon Tweeks one offers 10mm, 8mm and 6mm sizes. That'll
    be what? External pipe diameter?
    From that, I suppose I'll want a 6mm, right? I mean, 10mm is
    massive.....
  2. The Older Gentleman
    The Older Gentleman says... I bought something similar[1] with 6mm fittings that's easy to operate
    from a lawn mower repair shop locally, it cost me a fiver.
    [1] I'm using it in the fuel line attached to the bottom of a 1 litre
    mini-moto fuel mixing bottle that I'll be using as a substitute fuel
    tank when I balance carbs.
    Lozzo, Oct 11, 2006
  3. Nice idea on both counts. Ta.
  4. The Older Gentleman
    chrisu Guest
    don't be a pikey - buy a pingel fuel tap
    chrisu, Oct 11, 2006
  5. A what?
  6. The Older Gentleman
    snip>
    Pipe sizes are usually measured in the bore because that's the bit
    that matters, the outside of the pipe only changes according to the
    pressure the pipe is being put under or where it's being used.
    Andy Bonwick, Oct 11, 2006
  7. The Older Gentleman
    JB Guest
    If you have to ask, you can't/won't afford it. They are a piece of art,
    sculpted from purest Costalottium. Firend has one on his old Z1100, and to
    operate it is almost a sexual experience.(1)
    JB
    (1) Ok, I'll admit it. I must get out more.
    JB, Oct 11, 2006
  8. The Older Gentleman
    I had to buy a brass spigot to fit to the bottom of the fuel mixing
    bottle, I got that from a Kart shop. They use them on the fuel tanks so
    they can mount the fuel feed anywhere they like when mounting the tank
    in different positions. That cost me 3 quid and came with a Viton O-ring
    to seal it. All told the whole set-up cost me about a tenner, but it'll
    save me so much bother when i'm doing the balancing.
    Lozzo, Oct 11, 2006
  9. The Older Gentleman
    JB says...
    Something like this:
    http://www.bellacorse.com/bce020.htm
    Lozzo, Oct 11, 2006
  10. The Older Gentleman
    JB Guest
    Yup. With a 3/8" bore ffs! Because he once paid a visit (and *shedloads* of
    cash) to a certain Mr Ray Debben of Zed drag racing fame. The _only_ way to
    blow your £4k redundancy payout, or so he said at the time.
    JB
    JB, Oct 11, 2006
  11. The Older Gentleman, Oct 12, 2006
  12. The Older Gentleman wrote
    Mole grips. Although a more elegant solution is locking arterial
    forceps.
    steve auvache, Oct 12, 2006
  13. The Older Gentleman
    JB Guest
    But it _replaces_ the standard one, so where's the problem? (apart from the
    cost of course)
    JB
    JB, Oct 12, 2006
  14. The Older Gentleman
    TOG Guest
    JB wrote:
    No, it doesn't. Not on the Z650, anyway, which doesn't have that type
    of spigot but a double-bolt arrangement.
    TOG, Oct 12, 2006
  15. The Older Gentleman
    JB Guest
    <TOG@Toil>; <>; <>
    wrote in message
    There are adaptors supplied specific to each model. The basic fuel tap
    attaches into this plate. For the Z1100 it was as you say, an ali plate with
    two mounting bolts and a viton sealing 'ring' inset into the mating surface.
    If you are planning to keep the Zed, I'd spend the cash. You won't need
    another.
    JB
    JB, Oct 12, 2006
  16. The Older Gentleman
    *SPLUTTER*
    You don't know TIG very well, do you?
    _______
    Ace, Oct 12, 2006
  17. The Older Gentleman
    Or TOG, for that matter.
    _______
    Ace, Oct 12, 2006
  18. The Older Gentleman
    TOG Guest
    Ah, right. That's useful. Wonder where I can get them in the UK?
    Although, for that money, I might as well get a new OE Kawasaki
    non-vacuum tap.
    TOG, Oct 12, 2006
  19. The Older Gentleman
    antonye Guest
    Why not just buy some dry-break (aka Quick Release) connectors
    for the fuel line? I think I may have some spare in the garage so
    if you let me know what the fuel hose i/d is then I'll check if they
    are suitable.
    antonye, Oct 12, 2006
  20. The Older Gentleman
    JB Guest
    <TOG@Toil>; <>; <>
    wrote in message
    http://www.debben.co.uk/acatalog/More_Info.html
    JB
    JB, Oct 12, 2006
